Any one flown Corp into MMCU??
Nordo
Post by Nordo »
Has anyone flown into MMCU - Chihuahua/Gen R Fierro Villalobos Airport?? I can't find a lot out about this airport and my client wants to look at going there in the future. Trying to find an FBO and handler for customs, but all I found was a phone number that lead to a guy who spoke no english. Any Info would help, provided its written in English (my spanish is as good as my German!!).
Thanks.
I fly because it releases my mind from the tyrony of petty things.
all_ramped_up
Re: Any one flown Corp into MMCU??
Post by all_ramped_up »
You try checking Ac-U-Kwik?
Here's an e-mail for the Airport from the Grupo Aeroportuario Centro Norte - chihuahua@oma.aero
http://acukwik.com/AirportInfo/MMCU
Hope this helps! The Control Tower number is listed as well... chances are there's someone up there that knows some English.
wallypilot
Post by wallypilot »
We use Pegasus Flight Support for all operations in Mexico. They will most likely have an agent available for that airport, but if not they can make a recommendation. They are not cheap, but they make sure all the permitting, customs, and flight plans are done correctly.
http://www.fly2mex.com/index.asp
I have used Pegasus in MMCS, MMQT, MMZC, MMVR, MMSD, MMUN, and MMPR. Always great service.
Kerosene Cowboy
Post by Kerosene Cowboy »
I have been in MMCU twice this fall. All good, very similar to MMUN,MMSD,MMPR. We used Colt for handling, overflight, and fuel. Pegasus has a nice FBO, they are very easy to work with.
Nordo
Post by Nordo »
Thanks guys. It can be a challenge sometimes to get info into some of these places!! I usually use a handler for the first flight into a place I have no experience with then do it on my own once I have some contacts. But some places it seem very hard to get hold of the right people.
Anyway, its been solved through handlers.
Post by bizjets101 »
Mexico Mandates eAPIS for Private Aircraft Operators
Click Here. Under new rules that took effect this week, private aircraft operators flying into or out of Mexico must electronically submit flight, passenger and crew information to Mexico’s National Institute of Immigration agency at least one hour before arrival or upon departure.
x-wind
Post by x-wind »
Hey, thanks for passing that info along!
Edit:
Thanks for all the content contributions too.
Return to “Corporate”
