New Service Bulletins for Vans Aircraft
Share ideas on building aircraft.
AirFrame
Post by AirFrame »
Posting here in hopes of capturing RV owners who aren't already watching the Vans site or vansaircraft.com regularly.
SB14-01-31
RV-6/6A, RV-7/7A, RV-8/8A
Hoizontal Stabilizer Cracks
SB14-02-03
All RV-3, 4, 6/6A, 7/7A, 8/8A Flying aircraft
Cracks in Elevator Spar
Both recommend grounding the aircraft until an inspection is performed. Until the reinforcements are added, this becomes an annual inspection item.
LONG discussion on Vansairforce, just search for the SB number and you'll find the threads.
Schooner69A
Re: New Service Bulletins for Vans Aircraft
Post by Schooner69A »
Airframe: thanks for that. I'd been notified on other means, but had not checked into it. My HS is hanging on the wall so it should be easy to modify as per "non-flying" plans.
John
Return to “Homebuilders”
