Westjet flight to dominican from toronto
Cessna driver
Post by Cessna driver »
Heard had to dump fuel and return to yyz, anyone know what happened?
tbaylx
Re: Westjet flight to dominican from toronto
Post by tbaylx »
Well unless WJA started flying something bigger than a 737 your source is on the same stuff Rob Ford is doing. The 737 is not equipped to dump fuel.
Cessna driver
Came through word of mouth, no some one who was on the flight (non aviation related) who said they had to dump fuel
Brown Bear
Post by Brown Bear »
Should probably delete the thread rather than scare the crap out of everybody?
:bear: :bear:
Cessna driver
Well it would be an "incident"...and i posted in "Accidents, Incidents....etc"
Brown Bear wrote:Should probably delete the thread rather than scare the crap out of everybody?
please this is so scary... possible bad press about westjet... the world is ending...
Brown Bear
Cessna driver wrote:Well it would be an "incident"...and i posted in "Accidents, Incidents....etc"
Well, since a 737 CANT DUMP FUEL, it's not even an incident, now is it?? It's a crock.
It should be posted under "Crocks and Rumours".
:bear: :bear:
BE20 Driver
Post by BE20 Driver »
altiplano wrote:It should be posted under "Crocks and Rumours
Isn't that what this whole website is about?
Bazinga!
PositiveRate27
Post by PositiveRate27 »
Minus an "r"
PositiveRate27
Whoa, inadvertent viking ftw!!
^^ ^^ ^^ muhahahahah
GGCC
Post by GGCC »
i'd say it fell under the "overdue aircraft" category.... :?:
“All men dream ....at night, but the dreamers of the day are dangerous men, "
Lawrence of Arabia "abridged"
Cessna driver
Flight aware shows it going over florida, then turning back and going into a hold, then returning to YYZ.
WJA 2506
GyvAir
Post by GyvAir »
Did you mean over Virginia, rather than Florida?
Little bit defensive there... seems like an aircraft diverting all the way back to YYZ from the southern US is a reasonable inquiry and topic for a thread in this category. Since you appear to have some stake maybe you could enlighten us on the reason?
Maybe they flew all the way to VA and back because it couldn't dump fuel? 737 and all that, you know.
KAG
Post by KAG »
Did I miss something? Was there an engine failure or other mechanical reason the plane shouldn't turn around...maybe it was as simple as a snag that would have grounded ac at destination and opps would rather have the tail home, or maybe if they absolutely needed to burn gas anyway why not return to yyz if it was safe to do so.
Chase lifestyle not metal.
A whole pile of unhappy passengers.
It sure is curious tho that the 737 is stuck to its -200 grandfathered roots without fuel dumping. I guess the A320 doesn't have it either though.
burhead1
Post by burhead1 »
They heard Justin Bieber was onboard, they were told to return. :smt040
jetsetfly
Post by jetsetfly »
It was a RH Bleed Light that came on and the reason they turned back was due to no Maintenance in The Dominican so good call by the flight crew
Cessna driver
jetsetfly wrote:It was a RH Bleed Light that came on and the reason they turned back was due to no Maintenance in The Dominican so good call by the flight crew
Thanks!
7thirtyseven
Post by 7thirtyseven »
Thanks!
Dont thank him, the "RH Bleed light" belongs in the same catagory as fuel dumping.... Fiction.
KAG wrote:Did I miss something? Was there an engine failure or other mechanical reason the plane shouldn't turn around...maybe it was as simple as a snag that would have grounded ac at destination and opps would rather have the tail home, or maybe if they absolutely needed to burn gas anyway why not return to yyz if it was safe to do so.
What's wrong with the OP asking in a thread? Seems the replies that are giving him a hard time for asking are a bit touchy.
Thanks!
A center system hydraulic pump then? :rolleyes:
J31
Post by J31 »
Thanks!
Well Ok...splitting hairs......."Bleed Trip Off" requires maintenance actions to MEL if you are unable to reset it. Not to mention operating restrictions that that make it highly desirable to fix the problem for continued operations.
7thirtyseven
:smt023 :smt023
