icosco
Post by icosco »
MIQ
Re: A scantron error at TC? Is it at all possible...?
Post by MIQ »
I found myself in a similar situation like you when I wrote my CPAER. I luckily passed it after all but Navigation, which has always been my strongest subject, got the lowest mark on my written. I was really surprised too. If it would have been Air Law or Met I probably would have been fine with it, but Navigation? Unfortunately the results don't really reveal what you did wrong. It only tells you that you have to study again how to calculate a magnetic heading... Well thank you. What I found a little bit difficult during the exam is, that they give you that massive laminated VNC which is absolutely unhandy, some lousy markers and a pencil. With that you have to plan a cross country and then they for example ask you what the magnetic track is. You always get the 4 answers out of which one is definitely wrong, the other one would be right if you would forget to account for variation and then you have two answers which are very close to each other. For example a track of 54° or 53° degrees. The first time I drew that line it was literally right between the two. The second time I got 54° and the third I got 53°. So after wasting a good 10 to 15 minutes on that question I was still left with a 50/50 chance on something that should be very easy and straight forward to answer. I noticed that with a few questions, where the answers were not as straight forward as they should be. Somehow I also had issues with the NDB questions. And I wrote my CPAER after I had passed my INRAT and MIFR flight test...
Are there actual errors in the written exams? Possible but I don't think so. I think it's more a problem of vague answers and weirdly phrased questions.
After all, don't let this experience bring you down. There's multiple discussions on here about how there's almost no relation between getting good marks on the TC exams and the actual pilot skills.
CpnCrunch
Post by CpnCrunch »
MIQ wrote:answers which are very close to each other. For example a track of 54° or 53° degrees. The first time I drew that line it was literally right between the two. The second time I got 54° and the third I got 53°.
You aren't seriously suggesting that they want you to calculate the track to the nearest degree, are you?
trey kule
Post by trey kule »
First of all, they used yo do a check if there was a failure ti insure the score is correct. You can probably ask for it if they do not today.
Secondly, while the written exams may be thought be some to be of little if any relevance, failures on flight tests and written exams are one of the top ten indicators of a future accident (FAA).
If the mark is correct, forget the rationalizations, recognize that you have to study hard and properly, and get it done again.
Accident speculation:
Colonel Sanders
Post by Colonel Sanders »
Not sure how many FAA written exams you
have done, but they are simply an exercise
in memorization. Three answers, not four,
and no language trickery. MUCH easier to
pass.
Don't confuse TC and FAA written exams.
They are completely different animals.
As far as a good predictor for future accidents,
I think past accidents is probably better.
NASA did a study a while back and concluded
that the only consistent correlation that they
could really find with respect to pilot accidents
was that the younger the pilot learned to fly,
the less likely he was to have an accident.
icosco
Post by icosco »
icosco
Post by icosco »
Also, thanks for the input guys! Much appreciated.
Changes in Latitudes
That's a curious bit of information.
I can't find any documentation to back this up nor have I ever heard of this statistic. Do you happen to have a link in support?
Colonel Sanders
I think most people would agree that you
have to be a pretty cunning linguist to do
well at TC written tests. Whether or not
that particular skill transfers easily to the
cock pit, has always seemed a bit unclear
to me.
trey kule
Post by trey kule »
I have, in fact written several of the FAA exams, as well as some from other countries.
Absolutely, they are different. My personal experience is that the Canadian ones are generally pretty good comparatively.
But you are correct. Perhaps interpreting a US based is not applicable to Canada. I believe, for one thing, the US ratio of PPLs is far higher than in Canada, which could skew the results. Same with the age thing. Older pilot pilots are a maybe more accident prone than older pilots flying for a living.
Do you have the NASA link?
Colonel Sanders
My bad - it was the NTSB study, not NASA.
the NTSB determined that there was a significant difference between accident and non-accident pilots with respect to age.
What is interesting is the finding that pilots who started their flying careers later in life were more likely to fall into the accident group than those who earned their certificates or licenses at an earlier age. The reasons for this finding are speculative but not necessarily hard to believe.
Pilots who learn to fly earlier in life generally benefit from better motor-skill response and quicker mental or cognitive responses. One can imagine that as a situation crops up, the younger pilot is able to respond to the situation more quickly than an older pilot with the same number of years of experience.
trey kule
Post by trey kule »
Well , let me see. I thought it was an FAA study. Spent 1/2 searching it. Then read it was a NASA. Another almost an hour as I got sidetracked looking at age stats and accidents in the US.
TSB...do you, by chance know what to search under? Seems to me TC also made mention of the study in one of their safety letters.
The fact that the following recommendation was made, suggests some sort of statistic exists to back it up.
Develop a means to identify pilots whose overall performance history indicates
that they are at future risk of accident involvement, and develop a program to
reduce risk for those pilots. (A-05-027)
tractor747
Post by tractor747 »
So if you fail the written exam for the commercial licence twice and the instrument written twice before passing it that makes you a dangerous pilot?
trey kule
Post by trey kule »
I dont that any study concluded causation. Just correlation. I am still trying to access the definitive study though Changes found a related one....
