4 persons on board, 1 received minor injury to stiff neck - aircraft destroyed.
Aussie news with Youtube video
You going to say that every time a military pilot punches out?Illya Kuryakin wrote:Too bad pilots can't actually fly anymore. Not saying there was a choice....don't know the terrain, but?
Illya
But what?Illya Kuryakin wrote:Too bad pilots can't actually fly anymore. Not saying there was a choice....don't know the terrain, but?
Illya
Initially it was to satisfy the FAR spin recovery requirements. Since this aircraft was not able to meet the requirements, Cirrus had to offer an alternative solution that was at least just as safe.Crusty wrote:Another had a midair collision - which is exactly what inspired the Cirrus designer to install a chute in the first place.
Any references on that? The Cirrus isn't much of a radical design.trampbike wrote:Initially it was to satisfy the FAR spin recovery requirements. Since this aircraft was not able to meet the requirements, Cirrus had to offer an alternative solution that was at least just as safe.Crusty wrote:Another had a midair collision - which is exactly what inspired the Cirrus designer to install a chute in the first place.
I don't think you need a radical design for some spin modes to be unrecoverable.ahramin wrote:Any references on that? The Cirrus isn't much of a radical design.trampbike wrote:Initially it was to satisfy the FAR spin recovery requirements. Since this aircraft was not able to meet the requirements, Cirrus had to offer an alternative solution that was at least just as safe.Crusty wrote:Another had a midair collision - which is exactly what inspired the Cirrus designer to install a chute in the first place.
Section 23.221 of the Federal Aviation Regulations (14 CFR 23.221) requires that single-engine,
normal category airplanes demonstrate compliance with either the one-turn spin or the spin-resistant
requirements. The airplane, for spin recovery compliance, must recover from a one-turn spin or a
three-second spin, whichever takes longer, in not more than one additional turn after the controls
have been applied for recovery. The Cirrus SR20/SR22 are not certificated to meet the spin
requirements or spin resistant requirements of 14 CFR 23.221. Instead, Cirrus installed an Airplane
Parachute System (CAPS) that was FAA-approved as part of the SR20/SR22 type design.
Exactly!Big Pistons Forever wrote:To all those chute haters I have one question. Are you really OK with passengers dying when their life could be saved if the pilot pulled the red handle ?
I'm pretty sure that once you pull the chute, unless you happen to land on a huge stack of empty cardboard boxes, the airframe is going to be written off.frozen solid wrote:I know the aircraft in the original post was destroyed, and indeed it looks pretty banged-up. But in general, when the 'chute is deployed, is that the end of that airframe, or is it possible to repair the skin where the chute webbing rips out? If you pull the chute are you condemning the plane or is it possible to get lucky and save the plane as well as yourself when you pop the 'chute?
I read photofly's reply. Here's Cirrus's explanation of their engineering choices regarding spin prevention and recovery:ahramin wrote:Any references on that? The Cirrus isn't much of a radical design.trampbike wrote:Initially it was to satisfy the FAR spin recovery requirements. Since this aircraft was not able to meet the requirements, Cirrus had to offer an alternative solution that was at least just as safe.Crusty wrote:Another had a midair collision - which is exactly what inspired the Cirrus designer to install a chute in the first place.
It deliberately conflates spin testing and certification. Almost all 4-seat designs are spin tested, and must be recoverable after at least two turns. The Cirrus either isn't tested, or failed. Which do think it is?Aerobatic designs such as Extra and Sukhoi products are, of course, tested and certified for spins – but mainstream general aviation four-seat designs such as Cirrus, Cessna (182, 350/400), Diamond, Piper etc. are not certified for spins. Few 4-seat designs have ever been certified for spins.
There is much more to it than that as every possible scenario has to be tested multiple times. I believe the testing program to certify the Pa 28 for spins involved more than 200 spins.North Shore wrote:^ Isn't that just two more flights, though? One at MTOW, full forward CoG, and the second at full aft CoG?
I was a little surprised to read that! I'd looked into this several years ago and didn't find any examples of a Cirrus having been repaired after CAPS deployment. What I recall reading, but can't find at the moment, was a statement on the Cirrus website to the effect that the plane wouldn't be economically repairable after using the chute.Big Pistons Forever wrote:Also FWIW 10 Cirrus aircraft that deployed the Chute were later repaired and are still flying
To add to the reference photofly posted, this is where I learned about it:ahramin wrote:Any references on that? The Cirrus isn't much of a radical design.trampbike wrote:Initially it was to satisfy the FAR spin recovery requirements. Since this aircraft was not able to meet the requirements, Cirrus had to offer an alternative solution that was at least just as safe.Crusty wrote:Another had a midair collision - which is exactly what inspired the Cirrus designer to install a chute in the first place.
Part of me says that the marketing value of "can recovery from a one-turn spin without pulling the chute" would make it worth the testing programme expense. But another part of me thinks the official line from Cirrus is "pull the chute - we don't want the bad publicity of you thinking you're good enough to recover from a spin even if our test pilots are, then killing yourself and your passengers when you could have pulled the chute earlier on and lived."ahramin wrote:Good point photofly, but I'm thinking not tested rather than failed. They had to test the chute in a spin, and it worked. At that point further spin testing becomes an unnecessary expense.
Jeez 200 spins how **%*& high were they?Big Pistons Forever wrote:There is much more to it than that as every possible scenario has to be tested multiple times. I believe the testing program to certify the Pa 28 for spins involved more than 200 spins.North Shore wrote:^ Isn't that just two more flights, though? One at MTOW, full forward CoG, and the second at full aft CoG?
An excerpt from the reportCpnCrunch wrote:The crash near Sundre would seem to suggest that the Cirrus isn't all that easy to get out of a spin, at least when loaded up with 3 people:
http://www.tsb.gc.ca/eng/rapports-repor ... 0w0155.asp
