Fuel Feed failure for a single engine Cessna
A Question
Has anybody ever experienced a spontaneous failure for fuel to flow from a wing tank in a Cessna when "both" was selected.
By spontaneous I mean the fuel system was working normally and then for what ever reason one tank failed to flow fuel to the engine.
Note I am not interested in situations where on the first flight after major maintenance ( ie wing removal/re-install, or fuel tank/fuel line removal replacement) there was a problem. In those cases there have been numerous reports of taped/cap lines which were not cleared prior to install.
timel
Re: Fuel Feed failure for a single engine Cessna
Post by timel »
Don't know if it helps.
I know a case of a pilot that took off and found himself with a semi working engine in downwind.
Ended up well, but the fuel selector was not well placed on both. Personally I would always turn it left right it a little to make sure it was well positioned.
Shiny Side Up
Post by Shiny Side Up »
Yes, a fuel selector valve was faulty. The selector while pointing at both, wasn't in both.
GyvAir
Post by GyvAir »
Haven't encountered this specifically on a Cessna, but perhaps a friendly neighborhood mason wasp visited?
GyvAir wrote:Haven't encountered this specifically on a Cessna, but perhaps a friendly neighborhood mason wasp visited?
I could see a blocked vent tube causing uneven fuel flow from the two tanks but I do not see how this would cause a total lack of fuel from one tank.
Piece of debris caught in either the screen of the pickup or the fuel selector itself. Could also be a venting issue; perhaps the offending tank doesn't have a functioning vented cap.
Post by ahramin »
I don't see how it could be a venting issue. One cap is vented, and the other tank is vented. The two tanks are connected by a crossfeed tube. If one vent plugs, the whole system is still vented. Isn't that why they added the vented cap in the first place?
timel
Post by timel »
Cessna's I've flown had no caps with fuel vents. If fuel selector is on both, means boths fuel tank can be vented from on tank? Interesting. Hope you give us the answer when you find out.
It's tough to find any Cessnas without vented fuel caps on both tanks. Just because it doesn't have the 'periscope' out the top doesn't mean it isn't vented. Most have very tiny holes and a rubber diaphragm in the center underneath.
It's unlikely, but I figure if there was one long term blockage (either the main vent or one of the caps) followed by a recent blockage of one of the same, then that would stop fuel flow from one tank.
timel
Post by timel »
Interresting!
Last one I saw kind of looked like this one.
That little orange thing in the center is the vent diaphragm I was referring to.... :wink:
timel
Post by timel »
Never though there could be a vent in that thing!
Colonel Sanders
Post by Colonel Sanders »
Would that be, because that's legally required
by AD 79-10-14 R1 ?
http://wwwapps3.tc.gc.ca/Saf-Sec-Sur/2/ ... 0-14R1.htm
Do people here normally operate their aircraft
without bothering to comply with AD's?
Docbrad
Post by Docbrad »
I've heard that any negative G for more than a few seconds may cause an engine to sputter
Oh, CS. Everyone knows that the only two ADs you need to worry about are CF90-03R2 and CF87-15R4 (er............... AD2011-10-09). :rolleyes:
Docbrad wrote:I've heard that any negative G for more than a few seconds may cause an engine to sputter
Yes, this is true.... .....but unrelated to the discussion at hand.
Remind me one day to tell you the story of Miss Shilling's Orifice. :P
Colonel Sanders
Oh, CS
People here keep telling me that I don't
have very much aviation knowledge and
experience compared to them, but I actually
recall when that AD was issued, 35 years ago.
JBI
Post by JBI »
Colonel Sanders wrote: People here keep telling me that I don't
Who on here says that you don't have very much aviation knowledge?
ogc
Post by ogc »
ahramin wrote: The two tanks are connected by a crossfeed tube.
Are they? Been awhile since ive flown a cessna but are the tanks not independant of each other?
Colonel Sanders
Older 172 POH (not online) shows same
interconnect tube between the tanks.
The original design did NOT have vented
caps on both tanks, see the 1979 AD.
Last edited by Colonel Sanders on Wed Aug 13, 2014 12:43 pm, edited 2 times in total.
GyvAir
Post by GyvAir »
A cross vent tube might be a more accurate term if we're talking typical 172.
As others have already mentioned, it would be pretty unlikely for a venting issue to completely stop flow from one tank.
Colonel beat me to it..
Post by ahramin »
I'm fairly certain that if the fuel selector has a both selection, the tanks have to have a cross vent tube.
Big Pistons, I don't really know why you are asking it, but an instructor of mine once had an issue in - I believe - a C172. He was low on fuel (but still legal), one tank was empty , which caused a vapour lock like effect and caused his engine to die. He glided on a highway, put extra fuel in it, let the engine cool down for half an hour and took off again.
Send me a PM if you want more details.
Cessna 182 does not have a crossover tube. You can select 'both' on it. Tanks have individual vents.
For the Cub I am building, you can select both wing tanks at the same time, and they will be vented through the caps alone.
iflyforpie wrote:Cessna 182 does not have a crossover tube.
Yes it does.
