IATRA
macestar
IATRA
Post by macestar »
If I get a PCC on a be10 is my IATRA good for life?
TeePeeCreeper
Re: IATRA
Post by TeePeeCreeper »
Nope.
Sorry to be the bearer of bad news!
All the best,
TPC
cdnpilot77
Re: IATRA
Post by cdnpilot77 »
And further to that, an IATRA is not required for the Be10.
FOD_Vacuum
Re: IATRA
Post by FOD_Vacuum »
There are BE10 fitted with Garrett engines which puts it into the "high-performance" category with an excess of a Vne higher than 250kts, requiring an IATRA or As.
cdnpilot77 wrote:And further to that, an IATRA is not required for the Be10.
cdnpilot77
Re: IATRA
FOD_Vacuum wrote:There are BE10 fitted with Garrett engines which puts it into the "high-performance" category with an excess of a Vne higher than 250kts, requiring an IATRA or As.
Fair enough!
Diadem
Re: IATRA
Post by Diadem »
Actually, no. The Garrett BE10 would require a high performance type rating, whereas the IATRA is required for two-crew type ratings. Only aircraft designated as requiring two crew members (see http://www.tc.gc.ca/eng/civilaviation/o ... t-1840.htm) require a two-crew type rating, so even if the AOC says that two pilots must be used, no model of the BE10 requires an IATRA. That's why one can be a captain on it without an ATPL.
cdnpilot77
Re: IATRA
I was too involved in other work to argue that point, it was just easier to submit...thanks Diadem
leftoftrack
Re: IATRA
Post by leftoftrack »
+1
Redneck_pilot86
Re: IATRA
Post by Redneck_pilot86 »
Genuinely curious here...how does a different engine increase the Vne? Another way to ask I suppose, what is it about the old engines that limit Vne?
