Starting approach at intermediate fix?
Sorry for all the ifr questions.
Question, can you start a gps approach from the intermediate fix instead of one of the iawps?
In the States there is a provision saying you can, as long as there isn't more than a 90 degree turn to final.
I can't find anything in the TC aim about it in Canada however. There is a blurb in the aim (9.16) stating you can go "straight in" from an IF but it seems to be talking more about just in lieu of a procedure turn for a traditional approach.
I know of a few approaches that would be a bit if a detour to go to an iawp instead of straight to the IF then straight in.
Re: Starting approach at intermediate fix?
Small tip, if you aren't flying or going to fly in the US, I wouldn't bother with learning their rules until needed.
Yes you can do what you've posted. If it's going to be a tight turn and farther away why bother? You can go to the FAF, IAWP, MAP etc etc
think twice before cutting corners.
depending on your aircraft which will have increasing performances as your career proceeds, you might have to think twice before cutting corner. you also have to consider your avionic eqpt in the equation.
unless vfr, just do the published procedure and you will always touch down wether or not you are familiar with the airport.
leftoftrack
+1 on doing anything that may cause more stress than what it will save you. Set the FMS up to do the most normal predictable stable approach that you can. No sense in trying to save time and money and going missed because you were unstable. If it were important to an employer they will have RNP approaches that can reduce track miles. The only wild card is ATC changing runways on you. You talk to anyone in a transport category airplane and the worst thing that happens on a regular basis is runway changes
The only regulation that I know of that relates to this is CAR 602.127, "Unless otherwise authorized by the appropriate air traffic control unit, the pilot-in-command of an IFR aircraft shall, when conducting an approach to an aerodrome or a runway, ensure that the approach is made in accordance with the instrument approach procedure."
An "instrument approach procedure" starts with the IAF, proceeds to the MAP, and then to the MAHP. My take on that is that, when you are cleared to fly a specific approach, you must fly the instrument approach as stated on the plate by going to the IAF and continuing all the way to the MAHP and holding at that point until you receive further clearance or you see the runway and have clearance to land. If you want to do anything other than that, you need to get clearance from ATC to do so when in controlled airspace.
When you're in uncontrolled airspace, there is no ATC and you can do whatever you like with regards to joining the IAP. You still need to abide by the altitudes and other restrictions on the plate.
You have to be careful when doing this though. In the prairies it's generally OK to go direct the IF and inbound but if you're around mountainous terrain, the difference in altitude between the minimum sector and the intermediate segment altitude might be quite significant and you would be better off starting at the IAF/IAWP. If you have an FMS make sure you're familiar with it - you don't want to get into a "what's it doing now?" situation when you're inbound on the approach.
“No one can realize how substantial the air is, until he feels its supporting power beneath him. It inspires confidence at once.”
-Otto Lilienthal
-Otto Lilienthal
Liquid Charlie
The other issue is the hardware -- some of the more common GPS units such as Garmin are not smart enough to accomplish approaches started inside the IF -- their little silicon brains sometimes just refuse to do what you think they should do -- I never had issues with the Universal but Garmin has surprised me several times ----- know your hardware --
ACTPA
ACTPA
In the Garmin G430/530 series you can activate any leg of the approach. I have been cleared the full LNAV and then been vectored to intercept the final approach course just outside the FAWP. When this happens you simply skip down the list of waypoints on the flight plan page with the cursor, highlight the end of the leg you wish to activate and double click the direct to key.Liquid Charlie wrote:The other issue is the hardware -- some of the more common GPS units such as Garmin are not smart enough to accomplish approaches started inside the IF -- their little silicon brains sometimes just refuse to do what you think they should do -- I never had issues with the Universal but Garmin has surprised me several times ----- know your hardware --
I would agree with the majority here, the most detail I've found on this straight from the AIM:
"The pilot has the option of proceeding by the route so cleared by ATC in a previous clearance, by any published transition or feeder route associated with the selected procedure, OR by a route present position direct to a fix associated with the selected instrument procedure".... yadda yadda.. and further more the pilot is supposed to advise ATC of the type of route and or procedure to be flown (which mostly I find they don't care).
In other words, any fix associated with the procedure may be chosen. At least that's my interpretation, subject to the caveats mentioned by others above.
sstaurus...
When you quoted the AIM you left out the last part which is the most important.. it continued, "...which will permit the aircraft to commence a published instrument approach."
So you are cleared to a fix where you may commence (begin; start) the approach.... not join the approach.
A number of approaches have multiple IAFs and multiple feeders/transitions. The blurb in the AIM is stating that when you're cleared for a particular approach (without specifics of where to start the approach), you have the option of following any feeder/transition or doing direct from your current position to any IAF to commence the approach.
If you would like to deviate from that, you require clearance from ATC. It's similar to requesting a contact approach - generally (considering good airmanship) you would reference an IAP when doing a contact approach and may choose to go direct the FAF to align the airplane up with the runway. Since you are not following the approach as laid out on the plate (IAF to FAF to MAP to MAHP), ATC requires you to get a specific clearance.
I don't believe that's what they mean.In other words, any fix associated with the procedure may be chosen. At least that's my interpretation, subject to the caveats mentioned by others above.
-Otto Lilienthal
-Otto Lilienthal
Liquid Charlie
Exactly my point -- the unit is too dumb to figure it out and you need to do a manual leg change --In the Garmin G430/530 series you can activate any leg of the approach. I have been cleared the full LNAV and then been vectored to intercept the final approach course just outside the FAWP. When this happens you simply skip down the list of waypoints on the flight plan page with the cursor, highlight the end of the leg you wish to activate and double click the direct to key.
ACTPA
ACTPA
RAC 9.16 Has all the answers. You most certainly can proceed to any intermediate fix (IF) on the final approach course without navigating via a designated IAF. You just have to be cognizant of the required minimum IFR altitude...most likely to be MSA, as you wouldn't be allowed to leave it until you are established on a published portion of the approach.
Also, if you're planning to do a contact approach, but still want to use the FAF. make sure you're aware of your particular GPS's parameters for automatic sequencing from terminal to approach mode. Most likely within 15 degrees of track centre line at least two miles behind FAF...or somewhere thereabouts.
Reading RAC 9.3, I see no mention of the word 'commence'. Unless the language has been changed since my albeit slightly outdated AIM. It just mentions that you are responsible for your own obstacle clearance should you choose your own route to a fix (off of an airway, route, or transition). In any case, I believe this is one where 3 TC guys would give you 3 different answers.eh3fifty wrote:sstaurus...
Gene Hasenfus
I've never understood why this is such
a conundrum for people.
If you're flying into an airport with ATC,
they will give you vectors.
If you're flying into an uncontrolled airport
out in the middle of BF nowhere, ATC couldn't
care less what you do - you own the airspace
until you cancel IFR in the air, or you call them
after you land.
If you're out in the middle of BF nowhere, the
100nm altitude applies, then the 25nm MSA,
then the PT altitude. Assuming you're approaching
from the PT side, just head for the FAF and
crank it onto the final approach course, drop
the gear and down you go to the MDA.
If ATC had their way, they'd vector you inside
the FAF, every time, with at least a 110 degree
intercept angle.
after you land.
intercept angle.
Gene says - "Always wear your 'chute!"
sstaurus..
I'm getting my information from a combination of sources. The "commence" word is used in the ATC MANOPS document.. the document that ATC uses and expects pilots know what they shall and shall not do.
http://i.imgur.com/ABUVezq.png
Look at 465.1 Note 1 (B).
The AIM isn't clear and the CARs aren't explicitly clear either. However, based on what I know I see all of these to mean that you must start the approach at an IAF unless cleared otherwise.
The CARs state: "...ensure that the approach is made in accordance with the instrument approach procedure." An IAP starts at the IAF, progresses to an IF (if one exists) then to the FAF, and then to the MAP.
The ATC MANOPS concurs with this based on its definition: "INSTRUMENT APPROACH PROCEDURE — A series of predetermined manoeuvres for the orderly transfer of an aircraft under instrument flight conditions, from the beginning of the initial approach to a landing or to a point from which a landing may be made visually."
So, if the CARs state that you must make the approach in accordance with the instrument approach procedure, and the instrument approach procedure starts at the initial approach fix (initial approach segment), then I think that's quite clear that you must start at the IAF unless otherwise cleared by ATC.
You're free to do what you want but that's my take on it and that's what I teach.
When you're in uncontrolled airspace, CAR 602.127(1) doesn't apply because there is no "appropriate air traffic control unit", and you may do whatever your little heart desires... as long as you comply with CAR 602.127(2) because that still does apply!
-Otto Lilienthal
-Otto Lilienthal
Eh3fifty,I'm getting my information from a combination of sources. The "commence" word is used in the ATC MANOPS document.. the document that ATC uses and expects pilots know what they shall and shall not do.
The ATC MANOPS tells ATC how to do ATC stuff. It is not mandatory reading for pilots. The RAC tells pilots how to do pilot stuff. The RAC says pilots can go to the IF, then pilots can go to the IF.
IAW does not mean that you must start at the IAF. It means that what ever part of the approach you are doing must be done IAW the plate. If you want to proceed direct an IF that is fine, as long as you are respecting the sector altitudes you are flying IAW the approach; that is, after all, why the work out sector altitudes when the TERPS an approach.The CARs state: "...ensure that the approach is made in accordance with the instrument approach procedure." An IAP starts at the IAF, progresses to an IF (if one exists) then to the FAF, and then to the MAP.
B208..
A slight clarification... the MANOPS and the TC AIM are both not mandatory for reading by pilots. Mandatory reading for pilots would be the CARs.
The TC AIM is recommended reading for pilots. Since it doesn't give a clear answer I have looked at additional resources. Considering that we have to work closely with ATC it made sense to check to see what ATC expects us to do when they give us an approach clearance. Makes sense right?
As far as going to the IF or not, you need specific clearance for that. Generally, what will happen is you ask ATC for clearance to fly the straight in LOC 26 approach via LONTU (IF) and they will give it to you.
Under RAC 9.16 STRAIGHT-IN APPROACHES FROM AN INTERMEDIATE FIX it says: "Subject to ATC requirements and local traffic conditions, a straight-in approach may be made from this fix." "Pilots may begin a straight-in approach from any depicted transition that intersects the final approach track inside the designated IF provided that ATC is aware of their intentions and subsequent manoeuvring is within the capabilities of the aircraft." "If the aircraft is badly positioned, laterally or vertically, after being cleared by ATC for the straight-in approach, pilots should climb to the procedure turn altitude,..."
It seems pretty clear that to do an approach from the IF requires clearance from ATC. Obviously, ATC clearances are only valid in controlled airspace.
Based on your interpretation I could fly the procedure backwards, or go direct the FAF or OBS the MAP and intercept inside of the FAF... of course maintaining the proper altitudes like you said. Or I could fly an RNAV and go from the IAWP direct to the FAWP... it'd still go active and I could fly the approach on the GPS. You'd have to be a bit silly to think that that would be legal without clearance! You should call your local ACC and see what they think about that. Ask to speak to the supervisor.
As far as Canadian approaches being designed by TERPS... they're not. They're designed in accordance with the Canadian document, TP 308 "CRITERIA FOR THE DEVELOPMENT OF INSTRUMENT PROCEDURES".
If MANOPS tells ATC that pilots will do a certain thing then don't you think it'd be good if pilots actually did that? Let's keep our brains on here.The ATC MANOPS tells ATC how to do ATC stuff. It is not mandatory reading for pilots. The RAC tells pilots how to do pilot stuff. The RAC says pilots can go to the IF, then pilots can go to the IF.
Do you have a reference for that? As far as I know, as I have said already, is that the IAP starts at the IAF and is defined as being the lateral route from the IAF to the FAF and to the MAP... you either do a landing or follow the rest of the IAP via the missed approach procedure. You're correct that the altitude restrictions are also part of the IAP. However, the 100NM Safe Alt is not part of the IAP and neither is the sector altitude.IAW does not mean that you must start at the IAF. It means that what ever part of the approach you are doing must be done IAW the plate. If you want to proceed direct an IF that is fine, as long as you are respecting the sector altitudes you are flying IAW the approach; that is, after all, why the work out sector altitudes when the TERPS an approach.
-Otto Lilienthal
-Otto Lilienthal
Dude, MANOPS doesn't say pilots must start at the IAF. If a pilot wants to go to the IF there is nothing stopping him from requesting it in controlled airspace, and nothing stopping him from just doing it in uncontrolled.eh3fifty wrote:If MANOPS tells ATC that pilots will do a certain thing then don't you think it'd be good if pilots actually did that? Let's keep our brains on here.
Yep, the RAC ref previously quoted by someone else in this thread.eh3fifty wrote:Do you have a reference for that?
Nope. The approach depicts headings and tracks. Flying the approach backwards would not be IAW the published approach.eh3fifty wrote:Based on your interpretation I could fly the procedure backwards,
In uncontrolled airspace you could, and in controlled airspace you could ask; if you felt like doing something funky. However, just because something is legal doesn't mean it is smart.eh3fifty wrote:...or go direct the FAF or OBS the MAP and intercept inside of the FAF....
A slightly different shade of the same colour.As far as Canadian approaches being designed by TERPS... they're not. They're designed in accordance with the Canadian document, TP 308 "CRITERIA FOR THE DEVELOPMENT OF INSTRUMENT PROCEDURES".
Just curious, are you in training to be a pilot, or a controller?
B208..
The only point that isn't clear in RAC 9.3 is when it says: "...by a route present position direct to a fix associated with the selected instrument approach procedure."
That could be interpreted as any fix associated with the IAP, however, since the CARs say you must follow the IAP and any IAP starts at the IAF, it's clear to me that the fix you choose to go direct to must be one of the IAFs... unless you have clearance to do something else.
Based on your two quotes I used, it seems we are in agreement now.
Those are the key points! My point was that to do anything other than going to the IAF (via direct or via a feeder route) and following the approach points in sequence, requires a specific clearance if in controlled airspace. This is clearly depicted in RAC 9.3.In uncontrolled airspace you could, and in controlled airspace you could ask
Yes, TERPS and TP 308 are similar but different. The SOPs for Sunwing's 737 and WestJet's 737 are similar but different... a slightly different shade of the same colour. But you won't see any Sunwing pilots using the WestJet SOPs or vice versa!A slightly different shade of the same colour.
A little jab at me, I see! No, I have an ATPL and fly for an airline. But thanks for asking.Just curious, are you in training to be a pilot, or a controller?
-Otto Lilienthal
-Otto Lilienthal
wingandaprayer
Just out of curiosity, how'd you aquire a copy of MANOPS? Normally only NavCanada employees have access to those documents.
"this is how you smile to someone you don't like too much; this is how you smile to someone you don't like at all; this is how you smile to someone you like completely; this is how you set a table for tea." ~ Jamaica Kincaid, "Girl"
I'm curious what the differences between TERPs and TP308 might be. Based on AC 803-001, TC seems to think they're the same.
You can download MANOPS from the web, if you look.
It clearly states that instrument procedures in the CAP must be based on TP308.1. Subsection 803.02(a) of the Canadian Aviation Regulations (CARs) states that no person shall publish or submit for publishing in the Canada Air Pilot an instrument procedure unless the procedure has been developed in accordance with the standards and criteria specified in the manual entitled Criteria for the Development of Instrument Procedures (TP308/GPH209).
2. Instrument Procedure Design Criteria contained in TP308/GPH209 are based on those contained in United States Federal Aviation Administration (FAA) publication Terminal Instrument Procedures.
3. The criteria contained in TP308/GPH209 is amended from time to time, in response to: changes introduced by FAA Terminal Instrument Procedures, changes to technology, and recommendations received from stakeholders.
It does say that they are based on the FAA TERPS but they are clearly two different documents.
As for differences, the TP308 is about 50 pages longer. Formatting accounts for a decent chunk I assume. TERPS has a lot of colour diagrams but some of their old black and white diagrams look pretty bad. TP308's are all clearly depicted and formatted to have a pretty consistent look throughout the entire document. We didn't get authorization in TP308 for LPV approaches down to 200' like the US has had for awhile. We only got approval in Change 5.3 which was issued on December 15, 2011. We still don't have any LPVs in Canada down to 200' as far as I know. Prior to Change 5.3, 250' was the lowest for an LPV in Canada.
I'm not going through both to find out all their differences. They're similar but different. Approaches in Canada are designed using TP308, not TERPS.
-Otto Lilienthal
-Otto Lilienthal
Everyone who's interested knows Canadian IAPs are designed to the same standards as in the US, but different to the European PAN-OPS.
Given the difference between TERPS and TP308 is important enough to you sharply to correct two (and now three) people across two different threads for referring to one and not the other, I was hoping for a more in-depth knowledge of those important differences than just the page count and the colour of the diagrams.
photofly..
As I've stated multiple times now, and as the TC Advisory Circular that you referenced states: instrument procedures in Canada are designed using TP308. TP308 is similar to TERPS.
Unfortunately, when the majority of communication is done by non-verbal cues and inflections in your voice, it is easy to misinterpret the tone of someones writing. I did not mean to sharply correct anyone. I simply stated that the approaches in Canada are based on TP308. Personally, I'd be glad to find that out. I'm interested more in what is correct than how my feelings are after I read something on the internet. I did not chastise anyone and I did not talk down to anyone with regard to TP308.
photofly, I must apologize because I don't have the time, nor the desire, to go through almost 1000 pages to find all the differences. I hope you understand. I already stated one difference with regard to LPV approaches but that seems to have gone clearly over your head. The burden should not be on me to prove exactly how different two documents are. The AC clearly states TP308 is the document used for instrument procedures design in Canada - please don't shoot the messenger!
-Otto Lilienthal
-Otto Lilienthal
