Clarification on SPEC VIS
radarbeam
Post by radarbeam »
Hey guys,
I am about to go write my INRAT and I am getting contradictory info on a/c categories for SPEC VIS. so, at the risk of getting shot down, allow me ask you the IFR gurus one simple question.
Are aircraft categories for SPEC VIS departure are based on groundspeed or indicated speed? Harvsair online is telling me to use indicated and Daunless soft app just failed me for using indicated!!! Argh! :rolleyes: :rolleyes:
My gut feeling is to go with groundspeed, as a headwind can change your spec vis pretty significantly...but I certainly can be wrong!
Thanks!
eeeroger
Re: Clarification on SPEC VIS
Post by eeeroger »
I would go with groundspeed exactly for the reason you stated.
ThatArmyGuy
Post by ThatArmyGuy »
+1
zulutime
Post by zulutime »
Groundspeed it is...
Page 16 of the CAP GEN ( new approach plate format) "Take-off Minimums" , which states that
quote
....pilots must comply with the Specified Take-off Minimum Visibility (SPEC VIS) corresponding to the aircraft category listed below (See Approach Chart Legend-Minima Box- for category speed ranges )
Unquote
So we go to page 65
" Instrument Approach Procedures" and see
Quote
The appropriate aircraft Category are determined by the pilot based on the airspeed at which the aircraft is to be maneuvered.
Unquote
Oxi
Post by Oxi »
How exactly does groundspeed have an effect on spec vis? Regardless as BPF stated with a source its the manoeuvre speed (IAS).
trampbike
Post by trampbike »
It's the IAS, as BPF pointed out.
Think ahead or fall behind!
DanWEC
Post by DanWEC »
Mistakes do happen with these trainers, but are you sure you read the question right? Definately KIAS for category. GS is for approach FPM and time. Should send a Dauntless an email about that.
radarbeam
Post by radarbeam »
Thanks for the feedback guys! I went back and verify and all dauntless Q's on SPEC VIS mention using GS to determine aircraft category so I fired them an email.
BTW I passed the INRAT today with a 92%, I'm pretty happy! The GF will be paying me a beer tonight too! :)
Post by ahramin »
Just curious, if it was groundspeed, how would you determine that when you are sitting on the ground trying to figure out if you are legal to depart?
rxl
Post by rxl »
Exactly. You only have limited control on groundspeed.
DanWEC
Post by DanWEC »
92% is an excellent mark! Congrats.
Groundspeed doesn't make sense. Imagine a circling approach. What is your groundspeed if there is any wind. It will be frequently changing as you turn.
DanWEC
Post by DanWEC »
You're supposed to pull out your e6b and map, and calculate your GS during the circling. Sheesh, some people don't remember anything from training. ;)
Rookie50
Post by Rookie50 »
radarbeam wrote:Thanks for the feedback guys! I went back and verify and all dauntless Q's on SPEC VIS mention using GS to determine aircraft category so I fired them an email.
Smokin...well done.
