AC Lining Up with a Taxiway SFO...?
complexintentions
Re: AC Lining Up with a Taxiway SFO...?
Post by complexintentions »
Even working in far more punitive cultures (Middle East, Far East) there has never been any consequences for a go-around no matter the reason. If the approach isn't working out, you do it again.
rookiepilot wrote:You really expect to get an honest answer on this one? :shock:
We get it rookiepilot, you have a hate-on for Air Canada but c'mon, give it a rest. Approach policy isn't a secret.
Rockie wrote:There are no consequences for doing a go-around ever. How foolish do you think it would be for an airline to adopt that kind of policy?
You're being disingenuous. Clearly there are no consequences for the go-around but there could be consequences for a mistake that made a go-around necessary.
For instance, I've no doubt that there will be consequences for the two pilots here, even though they did a go-around.
So, I ask again, if they had gone around at 700agl, would there still have been consequences? How low could they go and still "get away with it"? obviously 86 feet agl was too low. Where would the line be drawn?
As for the 2nd question pretty much every airline on the planet adheres to the stable approach policy which essentially begins at 1000 AGL. By then we have to be on the correct flight path to the runway with the final configuration selected. If that is not the case a go-around is mandatory. Further criteria applies at 500 feet or a go-around is mandatory.
OK. So they need to be on a stable approach by 1000agl. How much higher than 1000agl would they have to begin a transition from being lined up on the taxiway to be lined up and stable on the runway approach by 1000agl?
mbav8r
Post by mbav8r »
For crying out loud, they didn't know they were lined up with the taxiway, do you think they would've continued that low if they did!
confusedalot
Post by confusedalot »
Rockie wrote:There are no consequences for doing a go-around ever. How foolish do you think it would be for an airline to adopt that kind of policy? As for the 2nd question pretty much every airline on the planet adheres to the stable approach policy which essentially begins at 1000 AGL. By then we have to be on the correct flight path to the runway with the final configuration selected. If that is not the case a go-around is mandatory. Further criteria applies at 500 feet or a go-around is mandatory.
Go arounds were required to be reported in the SMS system for further investigation, at my last employer.
Old fella
Post by Old fella »
rookiepilot wrote:
photofly wrote:I have a question ... if the pilots had noticed their mistake at, say, 700AGL and gone around, what would the consequences internally within AC have been?
:shock:
Gonna ask rookie..... how many missed approaches have you done in the shit wx when the gales of November come slashing. Again I ask what is your background, you give me the appearance of somebody who hasn't been above 200kts and 10,000ft in anything with two engines.
:shock:
You know what, OF, your correct, and I'm not the only one. . Does that matter?
Last I looked this thread wasn't about me, or my experience, or any other poster's experience.
Also last I looked this thread was about a crew coming within a hairs breadth of causing a horrible accident in Visual conditions. Not the gales of November, so I'm not sure where that comes in here.
And it doesn't matter. Airlines, especially North American hold themselves up as THE standard for safe operations, far surperior to anyone else (which is a load of crap, BTW). So when an accident or near miss happens, expect to get questioned! And yes, some questioners might be sub 10,000 hours.
If Old Fella you want to see experience prerequisites for making comments, I suggest you set up a private closed forum for whatever you deem are the acceptable professionals.
I suggest sticking to the thread material. You look really foolish making an point by personally going after another poster when one doesnt like the question. Just answer it. Or don't answer. I don't really care.
I find it amusing how some seem to be such blind "team players", threatened by questions, stating with authority "nothing to see here, happens every day", it's all "media hysteria" and even implying the NTSB shouldn't even be looking at it. Well, they are.
Well, sorry, that attitude is going to get challenged.
:mrgreen:
Rockie
Post by Rockie »
photofly wrote:You're being disingenuous. Clearly there are no consequences for the go-around but there could be consequences for a mistake that made a go-around necessary.
I'm not at all being disingenuous. What you described is an unstabilized approach and this is what you asked:
I answered you. The answer is "nothing". Nothing for discovering the mistake, and nothing for doing the go-around. If you don't already know why that is it's probably a waste of time explaining it to you but I will if you ask.
photofly wrote:For instance, I've no doubt that there will be consequences for the two pilots here, even though they did a go-around.
Based on what?
photofly wrote:So, I ask again, if they had gone around at 700agl, would there still have been consequences?
Answered. Want me to repeat it a third time?
photofly wrote:How low could they go and still "get away with it"? obviously 86 feet agl was too low. Where would the line be drawn?
A line would be drawn at negligence or deliberate noncompliance. Were you there to say one or the other was the cause?
photofly wrote:So they need to be on a stable approach by 1000agl. How much higher than 1000agl would they have to begin a transition from being lined up on the taxiway to be lined up and stable on the runway approach by 1000agl?
They approach at around 150 knots. Figure out how long it would take whatever you fly to do it at whatever speed you fly at on the approach and extrapolate. Shouldn't be that hard for you and I'm sure you'll be in the ballpark.
Rockie
Post by Rockie »
At AC as well.
Shady McSly
Post by Shady McSly »
rookiepilot wrote:
Old fella wrote:
:shock:
:mrgreen:
You just fly PC flight sims, don't you...
Eric Janson
Post by Eric Janson »
Disclaimer:- I don't work for Air Canada and all the remarks below concern my Airline. I am in no way calling for anyone to be fired.
If I did a go-around at 700" there wouldn't be an issue - I would just fill out the reason. That would be the last I would ever hear about it.
Now if I had descended to 59' whilst being lined up on a taxiway with 4 Airliners on it - that's a lot more serious.
I'm 100% certain that would cost me my job.
Rockie
Post by Rockie »
Are you saying your company would just fire you without trying to find out why it happened?
You're still, rather hilariously, obfuscating. Nothing for discovering the mistake ... good. Nothing for the go-around ...very good. What about the consequences for making the mistake in the first place?
Could an AC pilot in severe VFR and with a perfectly functioning airplane line up on a taxiway, descend to 700', and do a go-around, fill in my form saying "lined up on a taxiway in error - oops" and never hear about it again?
If AC pilots can do it to 86' over four other airliners without even so much as a talking-to from the CP maybe I should reconsider AC as my first choice for international travel...
"The airplane made me do it.", lol.
But seriously, at what altitude does a minor error excusable under SMS or some self-reporting schemes become negilgence worthy of disciplinary action?
Rockie, if *you* had been looking out of the window that night, at four airliners on the taxiway on which you were lined up, at what altitude would you have called for the go-round?
ktcanuck
Post by ktcanuck »
Well, we have now had 27 pages of, mostly, name calling, experience doubting, pure rudeness, ignorance, arrogance and occasional stupidity interspersed with relevant good comment and, Rockie, should you care to browse all 27 pages you will find examples of them all.
When it comes out we are all sure the report will give us the experts' best guess or facts regarding the causes of this potentially catastrophic incident.
FWIW to me the fundamental issue comes down to this:
If the flight crew had performed the following, as suggested by the SAFO is there any doubt whether this incident would have occurred?
"D. Utilization of Available Resources: Effective CRM also establishes the use of all available resources including but not limited to:
• A briefing of the airfield diagram;
• A review of airport lighting including any approach lights systems (ALS);
• A review and discussion of Notices to Airmen (NOTAMS);
• Performance of the approach and landing checklists according to approved procedures;
• Use of approach navigational aids under both IMC and VMC conditions;
• Monitoring of the Automatic Terminal Information Service (ATIS) for information and changes to field conditions;
• Listening closely to all radio transmissions for pertinent information; and,
• Identification and verification of visual glide path information such as a Visual Approach Slope Indicator (VASI) or Precision Approach Path Indicator (PAPI) not only for glide path indications but also their location relative to the runway of intended landing.
And, if they didn't, how is that not poor airman-ship or even negligence regardless of why they didn't?
And if there was a reason why they didn't, a CVR that recorded the last 30 hours (technically trivial to effect) rather than minutes would be likely to provide clues as to why.
Wouldn't one good outcome of this incident be a change to CVRs to require longer recording times?
FWIW
I made my comment because I thought,
a) Photofly asked a very good question,
B) the AC cheerleader squad would be too spineless to give a direct answer. And I'm right on that.
Now I have a simple question of my own, for the Rockie and Complex crowd:
Did that crew, Yes or No, read and brief the Notam for the RWY 28L closure that night?
The choices are A) Yes B) No. Don't insult by claiming no one knows this.
Gee, can a lowly CPL ask a question about reading a Notam, or only those understanding the intricacies of the A320 PFD do that? :roll: I know it's complicated.
Cause NOT reading that Notam MIGHT explain a lot here.
Sorry for the sarcasm, but...........I don't hate AC. I hate the PR type spin.
Illya Kuryakin
Post by Illya Kuryakin »
Another 27 page thread on "mine is bigger than yours..l"
Can we move along to something new.....this has been beat to death.
Illya
Here's another couple of questions for Rockie, or anyone else who knows AC.
Who is the officer at AC who, with all the reports and interviews in from of them, makes the decision if this was negligence, and what, if any consequences the pilots should suffer?
What criteria do they use to make that decision?
photofly wrote:Here's another couple of questions for Rockie, or anyone else who knows AC.
How much union flak likely to be received. Convince me that doesn't play even a slight role.
Rockie wrote:Are you saying your company would just fire you without trying to find out why it happened?
The last two companies I have worked for have fired and/or demoted pilots for significant screw-ups that have made the news and for one of the companies, incidents that didn't make the news.
While my initial instinct for this case, if I were the boss, would not be punishment unless there was a history of issues, the idea of giving awards to people who save the day after creating an unsafe situation themselves(not making any comment on the SFO case) as we have seen in the past is ridiculous in my opinion.
rxl
Post by rxl »
There is no "union flak". The union plays an important role in first of all helping to determine the cause and then works with all concerned parties to prevent reoccurrence.
The union also provides the representation that all workers are entitled to to ensure fair treatment.
If that's flak, then let the guns blaze.
Old fella
Post by Old fella »
rookiepilot wrote:
Old fella wrote:
:shock:
:mrgreen:
Whatever you say Rookie as a single engine pilot (VFR ??)critiquing the operations of a major Canadian
Airline A320 type and its flight crew conducting a missed approach at a major International airport on what they did/didn't, should have/could have/required to. Fill your commentary boots.
:roll:
Actually Old Fella I'm about 1000 TT and as a %, a good deal of IMC time. Some even in sh-- weather too. But whatever.
Again that's totally irrelevant, and certainly not "experienced". Point being, a student pilot can determine something went seriously south here.
You're a professional pilot, (which I've never claimed to be here, ever) seriously labelling this a simple, run of the mill missed approach by another professional crew? Nothing to see here? Then why does the NTSB even need to do a report?
I'm just curious if the Notam was read and briefed. Is that question offensive?
Old fella
Post by Old fella »
rookiepilot wrote:Actually Old Fella I'm about 1000 TT and as a %, a good deal of IMC time. Some even in sh-- weather too. But whatever.
Again that's totally irrelevant. A student pilot can determine something went seriously south here.
Can we not call things what they are?
This thread just gets better.
1000TT single engine flying IFR.... coming up in the aviation world, I digress. Yes, I was a professional- retired for some time but professional enough to realize I am not qualified to pass judgement on an airline operation and its flight crew on what they..... well whatever. I don't even know how to start the engines on an Air Canada A320 let alone trying to get my head into that flight crew that night in SFO. If you and your single engine/student pilot brethren feel you can add to the discourse on AC ops, honesty what else is there for me to say. See ya!!!!!!
Neither am I remotely qualified, and please quote me where I overtly passed a definitive judgement on this crew, unless labelling this a serious incident does so. NTSB thinks so.
But then again, to call this a simple missed approach is a bit of a stretch, yes?
I asked a simple question, "Did this crew read and brief the Notam for the runway 28L closure?"
Since the response is to attack my lack of experience, suppose there is little for me to say, either.
Old fella
Post by Old fella »
:prayer:
rookiepilot you just don't understand.
On that approach that night the crew did not see anything that would indicate they were not lined up for the runway.
As I read what has been written about this incident even after they missed the approach they claim they did not see any lights that may have told them it was not a runway they were about to land on.
They did not see the yellow X in front of 28L either.
Weird.
