RAIC Pass benefits?
RAIC Pass benefits?
Are there any benefits that come with holding an Air Crew RAIC?
Ive heard about the obvious ones like the trusted traveller line at security, and Harbour Air in BC. But is there anything else?
Re: RAIC Pass benefits?
You used to be able to get discounts on food, but I think that’s a time gone by now.
What is the RAIC benefit for harbour air? What kinda discount etc?
IMHO the best benefit is you and however is accompanying you on personal travel get access to the Trusted Travellers line at security, also YYZ RAIC holders have a pretty good discount on the UP express fare.
Keep in mind that if you aren’t travelling through security for work purposes then you are not suppose to use your RAIC To access the trusted traveller line.
- Col. Panic
False. You cannot use NPS if you aren’t travelling for work purposes, but the trusted traveller line is for passenger screening of “trusted travellers” including RAIC holders.
Well it's more of an unofficial courtesy. It's been discussed before here, but I don't believe there's any language that specifically allows you to bring a companion, I could be wrong however.
That being said, just be sure that catsa at your specific airport lets you do it.
On that note am I the only one who find's the variances in CATSA rules/procedure between airports and in some case even within the same airport a bit mind numbing.DanWEC wrote: ↑Sun Feb 20, 2022 12:53 pm Well it's more of an unofficial courtesy. It's been discussed before here, but I don't believe there's any language that specifically allows you to bring a companion, I could be wrong however.
Here's the official language from CATSADanWEC wrote: ↑Sun Feb 20, 2022 12:53 pm Well it's more of an unofficial courtesy. It's been discussed before here, but I don't believe there's any language that specifically allows you to bring a companion, I could be wrong however.
Trusted Travellers include:
members of NEXUS and Global Entry programs;
currently serving members of the Canadian Armed Forces and U.S. military, including reservists, all with valid ID (no uniform required);
Canadian aircrew and airport workers with Restricted Area Identification Cards (RAICs);
international aircrew in uniform with valid airline ID; and
those accompanying these trusted travellers on the same flight.
https://www.catsa-acsta.gc.ca/en/trusted-travellers
Some shops and restaurants in the airports will give you an employee discount
That's great, thanks for the reference.tango308 wrote: ↑Sun Feb 20, 2022 3:27 pmHere's the official language from CATSADanWEC wrote: ↑Sun Feb 20, 2022 12:53 pm Well it's more of an unofficial courtesy. It's been discussed before here, but I don't believe there's any language that specifically allows you to bring a companion, I could be wrong however.
There's at least one restaurant in YYC domestic that gives enough discount to cover the tip. (but just the tipTC.Enforcement wrote: ↑Sat Feb 19, 2022 2:12 pm You used to be able to get discounts on food, but I think that’s a time gone by now.
10% discount on some restaurants at YUL. Although it's not RAIC dependent (for the restaurants before security, obviously). Any airport employee has access to the discount. This being said, just show up with any lanyard and an ID around your neck, and the cash attendant at most of those restaurants will give you the discount automatically, based on the assumption that you work at the airport.
wow no waytango308 wrote: ↑Sun Feb 20, 2022 3:27 pmHere's the official language from CATSADanWEC wrote: ↑Sun Feb 20, 2022 12:53 pm Well it's more of an unofficial courtesy. It's been discussed before here, but I don't believe there's any language that specifically allows you to bring a companion, I could be wrong however.
Can anyone get a RAIC, or do you need to be an airline employee?
Most vendors in YVR will give 10% off, some 15%, some 20%. Old sheet attached, no guarantee that it's still accurate but I got a discount a few weeks ago.
Only employees of a business operating at an airport that require access to restricted areas. Employees need to be sponsored by their employer then the pass is issued by an airport authority after obtaining a Transportation Security Clearance.
YVR EMPLOYEE DISCOUNT GUIDE.pdf
- (678.93 KiB) Downloaded 297 times
There were some liquor stores around the YYC airport that gave discounts. Railyard brewery just north of the airport gives a discount too.
Does anyone know if you can still use the “trusted travellers” line just with a yellow pass whether for deadheading or personal use?
Not 100% sure, but a yellow pass means you haven’t passed transport security clearance, so I doubt you would class as a trusted traveller..pilot96140 wrote: ↑Fri Jun 17, 2022 8:15 pm Does anyone know if you can still use the “trusted travellers” line just with a yellow pass whether for deadheading or personal use?
As for discounts, YEG offers a variety for airport employees, which can be found on the EIA website..
https://flyeia.com/corporate/careers/em ... -benefits/
Yup! A couple YVR Easter eggs..
Bring your RAIC to Capilano Suspension Bridge and it’s free.
Also, Whistler ski tickets are discounted with a RAIC. Forget how much but it was 10-20% if I remember correctly.
