Jazz, WestJet, assume United, Delta all get paid extra...I mean even the FAs do...
The first dozen Captains on the E2 got Christmas off officially for next year out of 200+ pilots. They also bid the entire summer.
But isn't Air Canada like the only airline on the planet with just short call reserve?
For one thing WJ vacation credit is 4.5 hrs vs whatever garbage AC gets in 2033
3:15
You are either intentionally misleading or not aware how it works.
You are either intentionally misleading or not aware how it workscdnavater wrote: ↑Wed Dec 25, 2024 11:39 amYou are either intentionally misleading or not aware how it works.
WJ vacation week is 5 days @4.5 credit per=22.5 per vacation week
AC 25/26 vacation is 7 days @2:55 per=20.42 per vacation week
26/27 is 7@3:15=22.75 per week
27/28 and beyond is 7@3:45=26.25 per week
So for this 2025 vacation bid you get 2 credit less for a week of vacation, after that you are ahead by .25 and the ahead by 3.75 which equates to almost an extra day off in that month
Ok, in that sense, WJ is ahead in the weeks department but my point is and you started out saying WJ gets 4.5 credit per day with no context added!737Drver wrote: ↑Wed Dec 25, 2024 12:23 pmYou are either intentionally misleading or not aware how it workscdnavater wrote: ↑Wed Dec 25, 2024 11:39 amYou are either intentionally misleading or not aware how it works.
AC:
Years 1 to 5: 2 whopping weeks of vacation
5 to 10: 3 weeks
10 to 25: 4 weeks
WJ:
Years 1 to 3: 2 weeks (so 2 years LESS ie BETTER)
4 to 6: 3 weeks (1 year LESS ie BETTER)
Onwards: 4 weeks (3 years less ie BETTER)
So I guess after a DECADE you have a point
And point is the daily credit of 4.5 hrs for a stat in lieu is BETTER
Yes. 11 stat day and 1.5x if working on 24/26th, 2x on 25thMan_in_the_sky wrote: ↑Wed Dec 25, 2024 7:23 am Do those companies also give stats days off ? We’re having an extra 11/12 days yearly to use as vacation.
So if you work christmas, or not, you get an extra vacation day since we’re still operating on all stat day.
So 3:15 is considered good? Because that's some hot garbage.Man_in_the_sky wrote: ↑Wed Dec 25, 2024 11:35 am3:15
Prior to departure is the earliest they can force you. Shorter is up to us with a 2 credit cash clear premium for short call
Most everything is pre-assigned days in a advance. If they short call you, just book off.
Don't you get into trouble booking off exactly when you are getting called 3.5hrs right before departure (or 1hr after because you just "found" your sickness)?PostmasterGeneral wrote: ↑Thu Dec 26, 2024 8:32 amMost everything is pre-assigned days in a advance. If they short call you, just book off.
Surprisingly, AC doesn't seem to care. Makes no difference if you book off sick ahead of time on Res, or wait till last minute. Just how the system works. That being said, it's a dumb waste of sick days to be doing this regularly for the reasons discussed...Me262 wrote: ↑Thu Dec 26, 2024 9:03 amDon't you get into trouble booking off exactly when you are getting called 3.5hrs right before departure (or 1hr after because you just "found" your sickness)?PostmasterGeneral wrote: ↑Thu Dec 26, 2024 8:32 amMost everything is pre-assigned days in a advance. If they short call you, just book off.
I hope everyone re reads this.737Drver wrote: ↑Wed Dec 25, 2024 12:23 pmYou are either intentionally misleading or not aware how it workscdnavater wrote: ↑Wed Dec 25, 2024 11:39 amYou are either intentionally misleading or not aware how it works.
AC:
5 to 10: 3 weeks
10 to 25: 4 weeks
WJ:
Well, at my company, on my roster, this is not happening, even though anyone who works on Christmas day gets double time (normally stats are regular time and OT is time and a half) and everyone gets 11 extra days of vacation in lue of stats whether you work them or not.TheStig wrote: ↑Wed Dec 25, 2024 8:34 am
I've always felt both the company and pilots would be better off paying overtime for stat holidays than extra vacation days in lieu, some greedy senior pilots would probably bid to work them and more junior pilots would be able to hold them off and less reserve coverage would be needed.
Where are you getting the 60% number from? Most people will be in the top year, pilots are not spread equally amount all the yearsnoreasterYHZ wrote: ↑Fri Dec 27, 2024 9:33 amI hope everyone re reads this.737Drver wrote: ↑Wed Dec 25, 2024 12:23 pmYou are either intentionally misleading or not aware how it workscdnavater wrote: ↑Wed Dec 25, 2024 11:39 am
AC:
5 to 10: 3 weeks
10 to 25: 4 weeks
WJ:
WJ has better vacation for over 60% of the pilots even with the "huge" vacation win just based on the fact you are at AN EXTRA WEEK OF VACATION.
But I thought WestJet wasn't even a comparable for Air Canada pilots??
Just embarrassing
