Sudbury tower.....er radio
Hey guys,
I used to fly IFR into Sudbury quite a bit but have changed jobs and haven't for a while. I remember when someone on here had announced that they would be closing the tower and putting in a FFS thinking among others that it would cause problems. I have been doing some flying in the area over the last little bit and in printing off the plate for Sudbury, I noticed that it had after all been changed.
NOW, I'm not trolling for a debate as to whether it has more traffic than this airport or that one.
My question is for the guys flying in there on a regular basis; have they noticed a lot of delays? Obviously a rush when it's IFR and there's a bunch of Bears, Jazzes and ect it's going to be worse than on a normal quick turn. Is it comparable to a Timmins power back and wait type thing or worse?
Just effin' curious.
Re: Sudbury tower.....er radio
Same as Timmins but they seem to like assigning approaches and SIDs when its busier.
I find it's busier than Timmins, especially at rush hour. I haven't found there's much of a wait that often in YTS, whereas SB will have you power back, feather, and wait more often.
Not nearly as bad as YTS, because they can get you on radar in YSB significantly lower. However, I do on occasion find myself waiting and waiting to get out. It is a hub for us, so we usually have 4-5 aircraft there at once.
The worst is when a Cessna is cleared for the approach and is 10 miles out with 200-1000 foot ceilings, then we aren't going anywhere for a while.
BTD
To add: It is definitely busier then YTS most days, but with the lower radar coverage I find the wait times less.
BTD
Thanks Navcanada for cutting back on safety and increasing delays! I was in YSB last week for the first time after they closed the tower. Wow, what a cluster f***k. And it was a SKY CLR day! I'll grant you it was during rush hour. A collegue had to wait 20 minutes on the ground before even getting a vrf dep clearance on a clear day!
If I compare with the time of the "tower era", it was way better then: more efficient, safe and less stressful.
My two cents worth
My two cents worth
Trapped in time, surrounded by evil, low on gas.
I am working at Sudbury FSS. I'm also a pilot so I can understand your frustration guys..
To answer your question, yes sometimes aircraft will get normal delays, especially in IFR weather and during rush hour. But it's usually not too long I believe. In VFR weather, most pilots will request VFR departures, or will cancel their IFR when arriving.
Waiting 20 minutes to get a VFR departure is extremely rare from what I have seen
, but it probably happened when both FSS and ATC were busy.
It's interesting how reactive people can be when they realizeit was not a good idea to begin with. I wish more people can be MORE pro-active with the obvious.
Anyway...no problem, glad you brought this topic up again...even if it started two years ago.
viewtopic.php?f=54&t=37804&hilit=Sudbury+tower
Anticipate a similar thread on the future closure of Hamilton... not yet slatted yet but it will come...soon...
Yeah, but Hamilton's just asking for it!I am Birddog wrote:Anticipate a similar thread on the future closure of Hamilton... not yet slatted yet but it will come...soon...
