Since you mention how difficult it is to operate in "Sub arctic temps", how do the other companies in YZF do it? Does First Air, Canadian North, Summit, Air Tindi, Arctic Sunwest all have one rampy without a ladder to prep each and every aircraft?
Donald,
Try not to get your knickers all knotted. You work for that red and white company don't you? Probably shouldn't throw stones in a glass house and all that when it comes to this stuff. The air of superiority that is complained about by the red team about the maroon team is exactly the same one the red team uses against the green team. While you may have tons of examples why one is better than another there are also plenty that can go the other way.
Regarding ulu there was enough seats so don't worry about that, besides if one wants to start looking at your side of the fence you'll find plenty of dirt there as well, just like everywhere else. SMS wipes everything clean anyhow doesn't it?
As far as getting up on slippery wings is concerned Buffalo is not alone there. I have seen a certain company with hercs in YK clean snow the same way, while not at the same angle it is a lot higher than the wing of a 46. How do the twin otters wings get cleaned in the bush again? How are the oils checked or the wing tents put on again when a ladder is not available? And why do they have those little ladder like appendages on the side of the twin otter, just behind the cockpit door, usually with convienient handle on the roof, vortex generation?
Take it from someone who has actually seen both sides of the coin folks, nobody is perfect. Try not to pick apart every little thing and just enjoy the show.
DW
When it stops leakin oil then you worry.
