Now that's an over run! (vid)
old_man
Post by old_man »
Aircraft held up pretty nicely until it went through the fence.
https://www.liveleak.com/view?i=437_1506590772
Re: Now that's an over run! (vid)
Somebody took gallons instead of litres?
Brantford Beech Boy
Post by Brantford Beech Boy »
:shock: In Soviet Russia, runway over-run you!
old_man
Post by old_man »
co-joe wrote:Somebody took gallons instead of litres?
Feet instead of meters might explain though.....
AirFrame
Post by AirFrame »
Given the lack of fireball at the end of it all, seems unlikely.
Forgot to release parking brake?
flyer 1492
Post by flyer 1492 »
Realized that they had left the vodka back in the barricks.
Sure seem to be going extremely fast for an RTO. Perhaps there was a major malfunction such as a flight control failure leading to such a high speed RTO. Looks like at least 100 knots off the end of the runway.
AuxBatOn
Post by AuxBatOn »
I am surprised they did not eject.
Going for the deck at corner
Posts are being made on another forum of an airspeed indocation problem. I suppose that can cause issues about when an RTO might still be safe.
I remember a Continental MD-80 did an RTO in LGA after running into an airspeed indication problem(forgot to turn on the pitot heat when it was snowing) followed by a delay in recognizing the seriousness of the issue and did an RTO above V1.
https://aviation-safety.net/database/re ... 19940302-0
While the sim faults for an airspeed problem seem to be fairly obvious, real world faults such as on that MD-80 can be more confusing and only partial. Delays in dealing with such an issue especially on a short runway, a contaminated runway, or on a takeoff with afterburner can lead to an overrun.
