Hunters Blundering onto Air Fields
ihunterapp.com told two hunters our glider field is crown land. So they shot two deer, drove across a runway - and were subsequently stopped by Fish and Wildlife.
We are the leaseholder. It seems ihunter doesn't check if crown land is under lease, or occupied, or an aerodrome.
If your 'drome is on crown land, don't forget your flak jacket.
Yes, I've sent my concerns to ihunter and the Ministry.
- youhavecontrol
Re: Hunters Blundering onto Air Fields
I have to do low passes to chase ATV drivers off the airstrip we use for training from time to time. One time I had to shut down and kick an old lawn mower part off the runway surface. ..silly rednecks.
You did not HAVE to report the hunters. If they were not interfering with aircraft or acting unsafe just inform them of the situation and move on. Perhaps a hunter will report your supposed low and unsafe flying someday. Far to many folks get law involved when common sense would do.
- confusedalot
Wouldn't a few perimeter signs around the territory indicate to hunters where they are and what they are dealing with?
It’s an offence under CAR 301.08(i) to discharge a firearm within or into the boundary of an aerodrome without the permission of the aerodrome operator. Unfortunately there’s no penalty associated with the rule, but it’s something you could put on a sign.
In the spirit of "What's right, not who's right", I'm with the idea of putting up some signs (assuming there aren't some already). The vast, vast majority of firearms owners and hunters are very safety conscious and mindful of regulations. If they are informed that an area is a no-go zone they will respect it.
"silly rednecks"
Little stereotyping are we?
- all_ramped_up
This.B208 wrote:In the spirit of "What's right, not who's right", I'm with the idea of putting up some signs (assuming there aren't some already). The vast, vast majority of firearms owners and hunters are very safety conscious and mindful of regulations. If they are informed that an area is a no-go zone they will respect it.
Uh-oh. Rednecks have only been an "ethnic group" for ten seconds, and someone is already offended!Moose47 wrote:"silly rednecks"
- youhavecontrol
As a born and raised rural Albertain, with dust, mud and oil in my blood... yeah. I'll call them what I am. ..not like they'd be embarrassed by that title anyways.Moose47 wrote:"silly rednecks"
- confusedalot
For any particular reason?pelmet wrote:Shoot 'em
I am not a hunter by the way, and I hate guns.
- Prairie Chicken
Well, there is a penalty, but it would be an effort to have an investigation initiated & action taken if warranted. In this instance where no harm was actually done, you're right, nothing much would likely happen.photofly wrote:It’s an offence under CAR 301.08(i) to discharge a firearm within or into the boundary of an aerodrome without the permission of the aerodrome operator. Unfortunately there’s no penalty associated with the rule, but it’s something you could put on a sign.
Prairie Chicken
Nope, Not even after an investigation.Prairie Chicken wrote:Well, there is a penalty, but it would be an effort to have an investigation initiated & action taken if warranted. In this instance where no harm was actually done, you're right, nothing much would likely happen.photofly wrote:It’s an offence under CAR 301.08(i) to discharge a firearm within or into the boundary of an aerodrome without the permission of the aerodrome operator. Unfortunately there’s no penalty associated with the rule, but it’s something you could put on a sign.
301.08 is not listed in Schedule II to subpart 103.08, therefore doesn't quaify as "designated" under section 7.6 of the Aeronautics Act. Therefore sections 7.7 to 8.2 of the Act don't apply and no monetary penalties are possible.
The only actions that TC can take against a transgressor (per Chapter 10 of TC's Aviation Enforcement Policy Manual) is oral counselling and suspension of a Canadian Aviation Document. Unless the hunter or hunters are also pilots (in which case their licences could be suspended) the only thing Transport Canada can do is invite them to an interview, no coffee no biscuits. And if they don't bother to turn up there's nothing further that can be done.
Cleaning a few deer out of the area isn’t always a bad thing:
https://www.google.ca/amp/www.cbc.ca/amp/1.4324293
From that article:nine sixteenths wrote:Cleaning a few deer out of the area isn’t always a bad thing:
"Sunwest is working with the airstrip operator on ways to make landings safer for wildlife, RCMP say. "
It's nice to see everyone's priorities are arranged in the correct order!
youhavecontrol wrote:...not like they'd be embarrassed by that title anyways.Moose47 wrote:"silly rednecks"
I was gonna say, a lot of the rednecks I know proudly wear the title...
I have had a very useful dialog with iHunter.
As well as amending data for our field, they will be looking into the larger problem that provincial and state land databases may not show air field data.
At present any other software developer using provincial and state land databases may end up showing air fields as unoccupied public land.
301.08 is prosecutable under 7.3301.08 is not listed in Schedule II to subpart 103.08, therefore doesn't quaify as "designated" under section 7.6 of the Aeronautics Act. Therefore sections 7.7 to 8.2 of the Act don't apply and no monetary penalties are possible.
Contravention of Part, regulation, etc.
(3) Except as otherwise provided by this Part, every person who contravenes a provision of this Part or any regulation, notice, order, security measure or emergency direction made under this Part is guilty of an offence punishable on summary conviction.
Aha. OK. But they'd need to be prosecuted in court first. TC can't just issue a fine.RatherBeFlying wrote:
- Prairie Chicken
Prosecution is the correct answer. It's also the reason there is almost no enforcement or action taken for 301--it would have to be very serious or a recurring offence for charges to be laid by TC or police.
Prairie Chicken
Who cares, how big was the animal they shot is the bigger question
"ihunterapp.com told two hunters our glider field is crown land. So they shot two deer, drove across a runway - and were subsequently stopped by Fish and Wildlife.
If your 'drome is on crown land, don't forget your flak jacket."
Talk about an over dramatic statement. As a hunter I can tell you that if I was shooting a deer on an airfield you would be completely safe unless of course you are doing a very low "low and over" supersonic so I couldn't hear you coming and not see you either. Do you know anything about hunting big game? Bullets are not sprayed all over the place. One or two well aimed shots with full understanding that there is nothing between you and the target, and nothing beyond the target that be hurt by a miss. And yes even gliders make noise (have my glider lic as well).
Not legal, maybe, unsafe, highly unlikely.
Skyhunter,
Pilot, Redneck, Hunter, horse rider, in that order and proud of them all.
Skyhunter,
The hunters bear all the responsibility here. Using a 3rd party app and trusting it is dumb. Since a grass strip is obviously cleared, that should have been enough to demonstrate it's occupied land. No signs required. This goes not just for hunters but anyone else who thinks that any open space is public playground. I put signs up at my place and that got rid of about half of the trespassers, the other half are just ignorant idiots or dumb kids.
Once again I will send this caution. You may have a fit about a hunter unknowingly being on your runway and causing no harm. BUT he may have a fit about YOU supposedly flying to close to dwellings or causing noise or some other bullshit. Remember what goes round comes round. Airplanes are quite visible and if you welcome RCMP or TC investigating your behaviour then carry on.
It seems like everyone is assuming the aerodrome operator called Fish & Wildlife, yet nowhere does is it said that the aerodrome operator, local pilots, or anyone else even called Fish & Wildlife, merely that they were the ones who stopped them. Perhaps a question for RatherBeFlying to clarify the occurence before everyone gets twisted out of shape...
