King Air at Gillam, MB
Plane down
King Air crashed in Gillam. All okay. Was a medi vac aircraft from Nunavut to Winnipeg.
Re: Plane down
What happened? Was it a planned fuel stop in Gillam?
Re: Plane down
Hard landing maybe, notam says disabled aircraft, runway closed till 5z. Not likely a crash, tsb wouldn't allow a/c be moved that fast.
Re: Plane down
Duel engine failure, landed short of runway on the ice and hit the shoreline. Knocked the gear off and more.
Re: Plane down
Duel engine failure. Landed short of the runway on the ice. Continued on hitting the rock berm and then stopped on the runway.
Re: Plane down
I thought it was around 6pm that this occured. How did you get that info so quick? Assuming you weren't in the airplane...
Re: Plane down
Lots of people on the centre freq at that time of day, so...RadicalRadial wrote: ↑Wed Apr 24, 2019 11:37 pmI thought it was around 6pm that this occured. How did you get that info so quick? Assuming you weren't in the airplane...
Bork Bork
Re: Plane down
This is going to affect someone's RFP
Re: Plane down
Whats RFP stand for?
Accident speculation:
Re: Plane down
Sorry, reference to the Manitoba privatization. Stands for Request For Proposals. The government is getting pitched by a bunch of medevac operators to get the province wide contract.
Crashing a plane probably doesn't look good for that, but on the other hand, crashing one without anyone getting hurt is pretty impressive.
Which company was operating the plane?
Re: Plane down
Request For Proposals. The air ambulance service in Nunavut is contracted to Keewatin and is up for renewal in 2022. Standard Govt. procedure is to request proposals from interested agencies before settling on one that will provide services.
Re: Plane down
How about you read the other comments from said poster...703doge wrote: ↑Thu Apr 25, 2019 6:35 amLots of people on the centre freq at that time of day, so...RadicalRadial wrote: ↑Wed Apr 24, 2019 11:37 pmI thought it was around 6pm that this occured. How did you get that info so quick? Assuming you weren't in the airplane...
Re: Plane down
Turbine dual engine failure or ran out of gas?
Re: Plane down
Three major possibilities for a dual failure...
1.)mechanical issues with both engines at the same time (Highly unlikely)
2.) Fuel contamination
3.)Too much Air in the tanks.
To be fair to my fellow aviators, I’d be betting on #2.
Correct that it doesn’t look good for a RFP bid..
- Rank Moderator
Re: King Air at Gillam, MB
Renamed the thread so the title was a little more informative.
Ps: It’s Medical Evacuation = MedEvac
Medi-vac is some sort of weird vacuum, just like shop-vac
Happiness is V1 at Thompson!
In my opinion If it was fuel contamination it would happen much earlier in the flight. How long is the flight from Iqaluit to Gilliam ? 2 hrs ??
Not necessarily, could be certain fuel tanks that were affected.
Except on a King Air, you transfer the aux fuel into the mains as there's room to accept it. By landing time, they'd long since have emptied the aux tanks and be running on the main tanks. Fuel would have been mixed long ago.
It will be interesting to see what the real investigators discover.
4th possibility is single engine failure compounded when you shut down the wrong enginemmm..bacon wrote: ↑Thu Apr 25, 2019 12:00 pm Three major possibilities for a dual failure...
Ran out of petrol and haven’t got the nads to admit.....oh wait, TSB hasn’t had their say. Check the uplift......,only ONE way I know of to have two PT6’s calve at the same time. Ya gots to feed ‘em.
Illya
Illya
We must wait for the TSB to figure out why they crashed and that could take years.
In the mean time we must not even think about what could have caused it.
