Encore wrinkles a Dash-8
C-FKWE, a WestJet Encore De Havilland DHC-8-402, was operating as flight WEN3362 from Fort
McMurray (CYMM), AB to Edmonton (CYEG), AB with 4 crew members and 70 passengers
onboard. During landing on RWY 12, the aircraft made abnormal contact with the runway. After
clearing RWY 12 on taxiway A2, the flight crew became aware that the nose tires had burst. Due to
thunderstorm activity, company maintenance were unable to attend to the aircraft to change both
nose tires for approximately 40 minutes. After deplaning passengers at the gate, a more detailed
inspection of the aircraft revealed wrinkled fuselage skins, left nose gear door damage, damage to
the forward pressure bulkhead, and the nose gear assembly. There were no reported injuries to the
crew or passengers.
crew or passengers.
Re: Encore wrinkles a Dash-8
Not surprising with the experience levels out there and the nasty landing habits of the Q.
I wonder if ground workers would walk to their car in the parking lot at the end of their shift and go home or stay inside where it's safe if there's thunderstorms in the area.
But on the plus side , there was no damage to the rwy.
We'll have to rewrite the conditions for a good landing:
A 'good' landing is one from which you can walk away. A 'great' landing is one after which the runway can be used again. An 'excellent' landing is one after which they can use the plane again.
Really? Are you aware that during a red alert , ramp personnel are not allowed to be on the ramp? I wouldn’t be walking around on a tarmac during thunderstorm activity. I wouldn’t be walking through a parking lot either.
More importantly I wouldn’t be landing an airplane in thunderstorms either.
The crew from AF 358 , as well as their insurance company , wish that they had followed your advise.
Zaibatsu wrote
Do you have the experience level for those crew members?
Do you know the circumstances of the accident?
The kind of comment is more than a bit unfair if it is just outright speculation.
Lots and lots of q landings done every day. And experienced pilots screwing up.
Not surprising?Not surprising with the experience levels out there and the nasty landing habits of the Q.
Accident speculation:
Those "ground workers" you're talking about are some pretty good AME's in YEG (that I know personally) that were trying their best to get out and off the active there. They wanted more than any to get that airframe out if there. YEG airport was having none of it of course. We're not talking about some knucklehead rampies here.
You worry about your own drivel and I’ll worry about mine, okay?trey kule wrote: ↑Sun Aug 11, 2019 3:47 pm Zaibatsu wroteNot surprising?Not surprising with the experience levels out there and the nasty landing habits of the Q.
I was actually talking about this particular Encore crew. But yes. I’m sure AF would in hindsight have preferred to wait for the TS to pass as well.
I've never flown a Q400, but flaps 15, and adding 20 kt to Vref in an 8g15 wind in anticipation of a GA? Then a full nose-down reaction?During the approach phase, the PF added 20 knots to the VREF speed in anticipation of a missed approach, which would involve flying in close proximity to the approaching thunderstorm and possible wind shear.
the aircraft touched down on the main landing gear within the touchdown zone at a speed of 142 KIAS. Shortly after the initial touchdown, the aircraft’s weight on wheels sensor indicated that the aircraft had briefly returned to air mode.
The PF then made a full nose-down elevator input. A bang and a nose-wheel shimmy followed, and the aircraft pulled to the left as it rolled out on the runway.
Vapp of 142 sounds screaming fast to me. Is this a normal thing to do in the Q instead of maybe waiting a bit?
Long runway almost always flap 15 when I flew the DH8D.
Less flap is better in gusty winds and turbulence too, seems that's the case here.
So flap 15 is normal for a long runway, but that Vapp doesn't make any sense to me.
Usual method is to add half the gust up to 10 knots onto the REF. 20 knots is added for ice contamination. The REF speed was not the issue here. The Q is routinely landed with REF speeds in the 140s. It lands a lot nicer that way, with a lot more tail clearance on that long body.
Sounds like at least one thing in common with the Jazz Q write off wrt a bounced landing recovery although this report doesn't actually say that. I'm assuming
Just guessing, but full forward elevator is not the proper bounced landing recovery?
that "air mode" means no weight on wheels..ie "flying"?the aircraft’s weight on wheels sensor indicated that the aircraft had briefly returned to air mode.
So flying 7 knots fast on approach caused this damage?
There is absolutely nothing to learn from this report. IMO
It looks like everything was basically done correctly and the PF screwed the pooch at the last second.
Ah well, I'm not armchairing, I wasn't there and the capt had some experience. But obviously it was a fuckup so it's hard to say the factors weren't factors.
That report is garbage. They imply that the higher speed caused the captain to push the nose down at low altitude.
They completely ignore the fact that the FO (PM) was likely on the last pairing of his line indoc and the captain would have had his hands full.
Shit happens. The passengers and crew are fine and the airplane still flies like any other Q400 out there.
I didn't read the report. 20 kt additive seems steep for 8G15. I would think 11 kt additive... but it's been a long time since I flew those planes.
Captain has some experience, but not a whole lot in the left seat. With 1700 on type, the upgrade probably wasn't all that long ago. Maybe a year?plausiblyannonymous wrote: ↑Mon Jan 20, 2020 6:36 pm That report is garbage. They imply that the higher speed caused the captain to push the nose down at low altitude.
