Hello All
I have my aircrew selection test coming up next month for the Canadian Air Force. The only trade i applied for is Aerospace Control Officer (AEC). There is not much that can be done it seems in terms of preparation for most of the tests but it seems like there are a few sections that I could prepare for . There seems to be a section that has written mathematical questions that they said would be based on Distance, speed, time and fuel consumption. Will i be able to use a calculator in this section ? Will i be allowed paper and pens to work out these problems or will I just have to do them out of my head?
Is there anything else I could do to prepare or is there any advice you can give me to ace this test, all imput will be appreciated.
Thank You
CAF Aircrew Selection Test
Re: CAF Aircrew Selection Test
Here is the CF's selection page if you haven't checked it out yet. you should have already received an email with the same instructions though.
http://www.rcaf-arc.forces.gc.ca/en/cf- ... guide.page
Found this, no clue if it is of any use,
https://pilotaptitudetest.com/knowledge ... air-force/
I found this little blog had some decent info in it before I went for my selection.
https://rcafpilot2be.wordpress.com/the- ... n-process/
