Overflying (R) Aerodromes where PPR is required?
PilotY
Post by PilotY »
Hi there.
I was practicing XC flight planning when I noticed one of my routes would be overflying a gliders airfield. They have an (R) next to their name on the VNC and in the CFS they are noted as needing Prior Permission Required. Now, my memory from the CARs tells me that I could overfly this Aerodrome at 2000ft AGL minimum, so long as I make contact on their ATF frequency, however, their ATF extends to 3000ft AGL and with a 5NM radius.
Therefore, are aircraft which do not have intention to land at that Aerodrome required to remain clear of the ATF area? Or can they overly the Aerodrome provided they are on the correct ATF.
Re: Overflying (R) Aerodromes where PPR is required?
ATF's impose no mandatory radio communications. Traffic not landing should not overfly an aerodrome below 2000' AAE (602.96(4)), but you're welcome to overfly at or above that altitude, and a call on the ATF is polite but not strictly required.
PPR is a request by the owner or operator and not a regulatory restriction; registrants of uncertified aerodromes do not gain a legal power to keep you from using the airspace around their aerodrome, beyond restrictions that apply to all aerodromes via the CARs.
If you land at a PPR aerodrome without permission you would be committing a trespass, but that's a civil matter and beyond the reach of Transport Canada or the Civil Aviation Regulations.
PilotY
Post by PilotY »
photofly wrote: Tue Aug 04, 2020 2:13 pm ATF's impose no mandatory radio communications. Traffic not landing should not overfly an aerodrome below 2000' AAE (602.96(4)), but you're welcome to overfly at or above that altitude, and a call on the ATF is polite but not strictly required.
Thanks for your response. Does the aerodrome being listed as (R) with PPR required change any of that?
PilotY wrote: Tue Aug 04, 2020 2:16 pm
No.
I’m pretty sure there’s some rules in Part III about occupying the maneuvering areas without permission of the airport operator.
Loon-A-Tic
Post by Loon-A-Tic »
Is 5 miles really that far of track to be a concern :roll:
iflyforpie wrote: Tue Aug 04, 2020 2:53 pm
a quick check and I don’t see anything.. can you investigate?
What about this one:
Prohibitions
301.08 No person shall
(a) walk, stand, drive a vehicle, park a vehicle or aircraft or cause an obstruction on the movement area of an aerodrome, except in accordance with permission given
(i) by the operator of the aerodrome, and
(ii) where applicable, by the appropriate air traffic control unit or flight service station;
It says you can’t park an aircraft without permission. It doesn’t say anything about landing, taxiing, or taking off.
It’s pretty clear that clause is all about non-operational activities on a movement area, hence parking, vehicles, obstruction, walking, standing etc. I don’t think there’s any regulation allowing an aerodrome operator to direct or restrict moving aircraft on the movement area; I think that’s a power reserved for qualified air traffic control officers, at a controlled aerodrome.
Heliian
Post by Heliian »
The gliders mention would have me avoiding that like the covid.
2R
Post by 2R »
Call the operator , sometimes they might maybe give you permission to land . Some people like to know who is landing is all . Been to a few places like that they enjoy their airport if you respect the property they might even let you return .
Case of beer usually works :)
praveen4143
Post by praveen4143 »
2R wrote: Sat Aug 08, 2020 12:22 pm Call the operator , sometimes they might maybe give you permission to land . Some people like to know who is landing is all . Been to a few places like that they enjoy their airport if you respect the property they might even let you return .
Agree on this. A lot of PPR aerodromes are such only to reduce or avoid liability. Last thing they want is for someone to flip an airplane and sue the operator saying that they didn’t keep the aerodrome perfectly manicured or something. I’ve been to a few PPR dromes after calling ahead and they’re usually okay with it and some were even very welcoming of me.
There's not a lot of point registering an aerodrome and putting it in the CFS if you want nobody to land there...
photofly wrote: Mon Aug 10, 2020 2:13 pm There's not a lot of point registering an aerodrome and putting it in the CFS if you want nobody to land there...
In MB you need the registration to get aerial markers installed.
What are aerial markers?
photofly wrote: Mon Aug 10, 2020 3:59 pm What are aerial markers?
That's what the hydro company called those colorful balls on the powerlines.
Ah, thanks.
Heliian
Post by Heliian »
I'll have to rifle through the cfs but there's many reasons why it would be marked ppr or pnr.
fleetcanuck
Post by fleetcanuck »
My understanding of the reason for the ATF extending to 3000AGL is that they tow the gliders to that altitude over the aerodrome. I would certainly want to be talking with them to avoid their traffic before flying through the ATF. As mentioned, the glider traffic can be heavy and difficult to see. Whenever I have flown through or into a glider ATF, I have found them to be friendly and helpful.
Squaretail
Post by Squaretail »
You should tell the owners of CFX2 that.
Are they stroppy?
