455tt wrote: ↑Mon Sep 14, 2020 4:03 am
Maybe you have not even heard of a slide rule. That's OK if not. It is what they used to do calculations before computers, in the days of manual type writers and slate chalkboards....
... Imagine you are time traveller sent back to the 1950's for ground school with your electronic devices and are attending a class: better to keep your modern devices secret, as the teacher and students will never understand these.
Goodness me, you're a patronizing little shit, sometimes, aren't you?
E6B advantages: you can use one with one hand, and in turbulence.
The batteries don't fall out when you drop one. They don’t leak either, and wreck two hundred dollars of equipment.
The E6B is way faster since you don't have to navigate through a series of menus to find the calculation that you want or type in numbers (that you can easily enter incorrectly)
The memory feature lasts for years: the one in my Cessna still shows the groundspeed of my last cross-country flight, I don't even remember when the flight was, but I could tell you today how fast I was going.
The instructions are printed on it: you don't need an instruction book (that you lost, or even if you had, were forbidden to take into an exam).
They don't muddle up the two different concepts of accuracy and precision, which is a vital distinction for pilots. Something the previous poster seems not to understand.
On the subject of thinking about your results: if you understand what turning the wheel to the left or right actually means, you're half way there. Similarly when you use the reverse: your wind triangle is drawn on the device for you and is really easy to interpret.
An E6B and an iPad with Foreflight are the two best things to have to hand in flight, in my opinion. Since that is what is important, those are the tools you should practice using on the ground.
