Questions for anyone with hearing aids:
I just got fitted with invisible-in-the-canal hearing aids. Was worked up years ago by an ENT and told nothing serious wrong but I’d some day likely benefit from getting hearing aids.
Any advice/experience on how this will affect my Class 3 medical? Do I just do the basic behind the back whisper test with the aids in or should I get my audiologist to do a formal hearing test with aids in place and bring this to the medical exam? Can I get my medical renewed on the spot or will CAME need to send paperwork to TC?
In the USA, you can get your medical approved with “hearing amplification required” so you can use hearing aid or headset with volume turned up. From what I’ve read, in Canada the only option in “hearing aids required”. Is this true?
Any issues with wearing headset over hearing aids? I have a Bose A20 which I’d like to continue to use.
Hearing Aids
Re: Hearing Aids
According to Standard 424...
https://tc.canada.ca/en/corporate-servi ... training-1
You can use hearing aid(s) for a Category 3 (PPL) medical exam but not for Cateogry 2 or 1 (CPL), and then the medical certificate is endorsed "Valid only when wearing a satisfactory hearing aid".
- RedAndWhiteBaron
Re: Hearing Aids
Just read through that list.
Interestingly, a "speech defect or stutter" is disqualifying for class I and III medicals, but not class II. Controllers are exempt from that one for some reason. Also, wearing prescription sunglasses at night is verboten, but it says nothing about regular sunglasses. Good reading.
Back on topic, the actual text is this:
Paragraph 31 is the whisper test, 32 is the pure tone audiometer test.Transport Canada wrote:For a Class I:
1.32 (2) The use of individual hearing aids during voice or practical testing is not permitted unless flexibility has previously been granted in accordance with Part IV, Subpart 4 of the CARs.
For a Class III:
3.32 (4) Where a hearing aid is required to meet the requirements of paras. 3.31 or 3.32 the validation certificate shall be endorsed "Valid only when wearing a satisfactory hearing aid".
Re: Hearing Aids
I'm now running on a "Private" certificate, but my restriction reads: "Must wear hearing aids or noise cancelling headset."
I actually have to remove the hearing aids when I wear NC headsets as there is some feedback in the aids when the NC is activated...
