IFR Take Off Considerations
An interesting conversation happened today while everyone was siting around in the fog and drinking coffee. Here's the scenario: you are in a private, single-engine, high performance airplane - call it a Cessna 210 for argument sake. The weather is 3/4 mile and 100' overcast. Can you legally depart?
Re: IFR Take Off Considerations
Is a Cessna 210 a high performance airplane ?
Doubt it !
Doubt it !
Depends on the runway but generally I would say yes. Don’t know if I’d want to.
For a private operator the only thing governing your legal takeoff is visibility.
With the ceiling at 100’ and not being able to return is limiting in a CASS operation and would require a take of alternate but you could still depart.
Yes, in this case. IFR departures are governed by visibility only. You will need 1/2 mile to take off.Spandau wrote: ↑Wed Sep 29, 2021 8:18 am An interesting conversation happened today while everyone was siting around in the fog and drinking coffee. Here's the scenario: you are in a private, single-engine, high performance airplane - call it a Cessna 210 for argument sake. The weather is 3/4 mile and 100' overcast. Can you legally depart?
Just because you can legally do something doesn’t necessarily make it a good idea…..
Not enough weather information to make any decision . What is causing the low ceiling ? What about temperature dew point spread ?
Ice ? Enroute Weather ? Destination weather ? Weather guessers accurate this week ? Probability of unforecast weather ?
Coastal ? Mountain ? Prairie ?
Where are the Fronts ? Cold fronts in summer and Warm fronts in winter create the most challenging weather conditions that demand respect in ANY aircraft , Civil or Military .
If I understood the OP’s question correctly he was asking if it was legal to depart.
The answer is Yes.
I expect we have all learned from the unasked questions about other considerations, whether it is wise etc. So much good information that had nothing to do with the question asked.
You gotta love the internet.
The answer is Yes.
Accident speculation:
This is only in company, take-off alternate are not required (should be) in 604wordstwice wrote: ↑Wed Sep 29, 2021 9:29 am For a private operator the only thing governing your legal takeoff is visibility.
Actually, this is just a hypothetical question at face value.2R wrote: ↑Wed Sep 29, 2021 1:33 pm Not enough weather information to make any decision . What is causing the low ceiling ? What about temperature dew point spread ?
But I thought it used to say in the Cap Gen that you needed 1/2 a mile and landing limits on a runway. Obviously I'm thinking of something else, but I just wanted the opinion of the learned herd. And yes, just because it's legal doesn't make it a good idea.
Of course you can.
All you need is 1/2 mile to takeoff.
If weather is below landing minima, you need a takeoff alternate but only for Part 7 operations for which this aircraft would be excluded from operating IFR under any weather conditions.
It’s also a single engine plane so if you have an engine failure you are out of luck no matter what. 3 miles and 1000 feet would make that impossible turn a necessary one (cue Interstellar music). What other return would have to be immediate vs continuing to destination? Fire? You won’t have a chance to set up for an approach anyways unless it’s a reciprocal one and it’s probably at higher minimums—did you think of that? Control or structural or low fuel or instrument problems make low minimums the least of your concerns. Sick passenger maybe?
I know a lot of mostly older and wealthier individuals who treat their Centurions like a PC-12 or a TBM850 but they are going to find themselves statistics one of these days.
A piston single is a cloud breaking airplane. Layer of fog giving you 1/2 mile VV001? Sure. Solid IMC up to 10,000 with ice? Even in a P210 with radar and TKS, not a chance.
Somebody (Budd Davisson, maybe) once called single-engine, single-pilot IFR "the World's Most Dangerous Legalized Sport", and I'm inclined to agree. But, as I said, it was just a hypothetical question.
Single engine piston IFR is one reason why the cirrus having a chute is a good idea. If it’s hard IFR and that engine quits your best chance is pulling the chute
- rookiepilot
This is why (SP, SE) IFR is much more complex than VFR....way more legal, yet not wise, options......then add icing and embedded CB's.
I've done my share but with some hard, (read conservative) rules.....
I'm not convinced a twin is that much safer ---at least in those first moments after T/O......losing one just entering IMC near the blue line speed, doesn't sound fun for an amateur like me.....
A very broad statement. Treat it with respect, but it doesn't have to be dangerous. Using that logic VFR at 500 AGL is fine, but IFR at 5000 ft with a cloud base at 500 AGL is not?
Depends on the definition of amateur, if amateur is someone that flies 20 hours a year I agree. If amateur is someone that doesn’t fly professionally but flys 200 hours a year an practices various scenarios then I disagreerookiepilot wrote: ↑Thu Sep 30, 2021 7:56 am This is why (SP, SE) IFR is much more complex than VFR....way more legal, yet not wise, options......then add icing and embedded CB's.
A twin might also not be much safer the first few seconds after rotation, but it sure will be the next few hours in cruise!
- oldncold
did my first ifr ride over 30years ago with ernie pool tc inspector great guy full of tips on ifr. during the ground portion of my ride
gave me a scenario of the rutland one departure out of ylw, which was. it's 200ft 1/2 mile can you depart in your twin Comanche. I knew the answer was yes ernie then said you are now at 600ft agl and your engine fails. what is the climb gradient required and environmental conditions your now single engine. Climb in ft per min. never forgot ernies wisdom of that lesson that I would be royally hooped. ride went well and he signed off my ir it. so to original poster make sure ya look up the climb gradient on the departure. to make sure that if the poop hits the fan you can meet the ft per nm or min in those imc min conditio
Correct me if I am wrong, but single engine in a twin you do not need to meet the climb gradients on the charts, you only need to make sure you don't hit anything.
There is no requirement to follow CAP Departure Procedures at any time, single engine or not.
My initial thought was that you still need to outclimb the obstacle clearance surface, which I thought was 48'/NM less than the published climb gradient but it turns out I was wrong and it's 24% less. That can be a big difference. I found this site provided some good reading on the topic:
https://code7700.com/doa_strategy.htm
For a private flight, there is no requirement to meet terrain clearance with OEI climb performance. If the engine quits on a single, you are definitely not out climbing the terrain, even in Saskatchewan! This is one of those places where your risk assessment has to decide whether it is an acceptable risk for you and your family.
So the question on a flight test, the legal answer may be yes you can legally depart, but the practical answer is much more complicated.
Thanks for raising an extremely valid point.oldncold wrote: ↑Fri Oct 01, 2021 11:13 pm did my first ifr ride over 30years ago with ernie pool tc inspector great guy full of tips on ifr. during the ground portion of my ride
gave me a scenario of the rutland one departure out of ylw, which was. it's 200ft 1/2 mile can you depart in your twin Comanche. I knew the answer was yes ernie then said you are now at 600ft agl and your engine fails. what is the climb gradient required and environmental conditions your now single engine. Climb in ft per min. never forgot ernies wisdom of that lesson that I would be royally hooped. ride went well and he signed off my ir it. so to original poster make sure ya look up the climb gradient on the departure. to make sure that if the poop hits the fan you can meet the ft per nm or min in those imc min conditions
In the Airline World we have a published engine failure procedure for every runway.
What people don't realise is that it only covers you to 1500' AAL. This is quite often still below MSA leaving you to figure out how to avoid terrain.
I've been in a situation departing at night from an unfamiliar airport where the normal departure and the go-around procedure was a right turn and the engine out procedure was a left turn towards terrain that was showing with the terrain mode selected on the navigation display. All 3 of us agreed that it would be a right turn after take-off.
Everywhere I’ve worked always has procedures all the way up to whatever the safe altitude is not just 1500’ since that’s pretty uselessEric Janson wrote: ↑Mon Oct 04, 2021 12:25 amThanks for raising an extremely valid point.oldncold wrote: ↑Fri Oct 01, 2021 11:13 pm did my first ifr ride over 30years ago with ernie pool tc inspector great guy full of tips on ifr. during the ground portion of my ride
This doesn't apply to the original post.fish4life wrote: ↑Mon Oct 04, 2021 4:11 amEverywhere I’ve worked always has procedures all the way up to whatever the safe altitude is not just 1500’ since that’s pretty uselessEric Janson wrote: ↑Mon Oct 04, 2021 12:25 amThanks for raising an extremely valid point.oldncold wrote: ↑Fri Oct 01, 2021 11:13 pm did my first ifr ride over 30years ago with ernie pool tc inspector great guy full of tips on ifr. during the ground portion of my ride
