Eagle Air
sunk
Eagle Air
Post by sunk »
Is this the new Keystone? Ran out of fuel and landed on the road North of Winnipeg.
Re: Eagle Air
What type of plane? What happened? When?
sunk
Re: Eagle Air
Post by sunk »
Navajo, Thursday and to much air in the tanks.
CpnCrunch
Re: Eagle Air
Post by CpnCrunch »
fish4life
Re: Eagle Air
Post by fish4life »
So close… yet so far considering the pilot should have made it to st andrews + reserves. Incredibly lucky they didn’t end up another statistic
Re: Eagle Air
That passenger sounds like a fun guy to have on board :-)
DanWEC
Re: Eagle Air
Post by DanWEC »
digits_ wrote: Fri Nov 03, 2023 10:43 am
The passengers up North are a different breed. They're unflappable. Whether it's cancellations, delays, or even the couple emergencies I've had, it's just another day at work.
Meanwhile you've got goofballs down here in jogging pants and sandals taking pictures of speed tape and losing their minds. ;)
Be like Bryon... (But don't be like fricken Eagle Air!)
pdw
Re: Eagle Air
Post by pdw »
Seeing here full pax/bags limits the fuelweight allowed to be taken up for W&B legality, sometimes it’s going to be a lighter weight fuel drawn from underground warmth, as possibly here. It also can be at a max age and at a min octane cut for the grade … all combining to consume it slightly faster going into that colder weather trip, .. and maybe not as much tailwind as is flight planned
IMO it’s potentially that type of consumption rate issue that plays into this type of situation esp in this area of Canada at this time of year ( the repeating event being hinted in a previous post above )
Re: Eagle Air
pdw wrote: Fri Nov 03, 2023 12:09 pm
Hmz... I find that highly unlikely. Usually in a navajo you set a fuel flow and get an airspeed. Even if that changes, you should have ample warning you're not going to make it to the field.
If you're referring to a change in fuel density, then that effect should be significantly less than a 30 minutes/45 minutes final reserve. It could be a factor , but a very minor one.
Did they fly CYAV - sachigo return, or was it a bigger trip?
The Hammer
Re: Eagle Air
Post by The Hammer »
Flew right by pickle, Red, Sioux look out, lac du bonnet too. All still have a gas....
rigpiggy
Re: Eagle Air
Post by rigpiggy »
Biggest safety devices in a Navajo
#1 jpi fuel totalizer
#2 gps
#3 ads-b
I WAS Pez
Re: Eagle Air
Post by I WAS Pez »
I never understand PDW.
SpyPilot
Re: Eagle Air
Post by SpyPilot »
PDW taps away in a language that I too am not conversant in.
Bede
Re: Eagle Air
Post by Bede »
This guy is an absolute boss.
I've never been on a plane where that happens, but I know they can fly with only one. So everybody kind of took pictures and was joking about it
We stopped in front of a house and a little kid came out and started taking pictures, so it was kind of funny that way. We were joking, 'Hey, your bus is here,' and that kind of stuff
But honestly, it was kind of pretty cool," Cassie said. "You always think, in the back of your mind, I wonder what would happen if this happened or if that happened. And in this case, I got to live out one of these experiences with no repercussions. [It] was sort of like a bucket list thing for me.
stef
Re: Eagle Air
Post by stef »
Re: Eagle Air
At night???
fish4life
Re: Eagle Air
Post by fish4life »
digits_ wrote: Sun Nov 05, 2023 9:52 am
At night???
Why not you’ve already done one illegal thing that day
Re: Eagle Air
Post by North Shore »
pdw wrote: Fri Nov 03, 2023 12:09 pm Seeing here full pax/bags limits the fuelweight allowed to be taken up for W&B legality, sometimes it’s going to be a lighter weight fuel drawn from underground warmth, as possibly here. It also can be at a max age and at a min octane cut for the grade … all combining to consume it slightly faster going into that colder weather trip, .. and maybe not as much tailwind as is flight planned
Really? What a load of bulls!t. Making the assumption that this is simply a case of not enough fuel, I can see your factors making 5, maybe 10% difference - certainly not enough to cover what should have been, at minimum, 30mins of reserve…
Happiness is V1 at Thompson!
CpnCrunch
Re: Eagle Air
Post by CpnCrunch »
fish4life wrote: Sun Nov 05, 2023 12:26 pm
At night???
Looked more like twilight, but you'd need to check what time they took off at.
Re: Eagle Air
North Shore wrote: Sun Nov 05, 2023 1:11 pm
Careful though, 10% of 5 hours is 30 minutes... ;)
J31
Re: Eagle Air
Post by J31 »
The Hammer wrote: Fri Nov 03, 2023 9:43 pm Flew right by pickle, Red, Sioux look out, lac du bonnet too. All still have a gas....
Pickle and Sioux are quite a stretch off his track to make a low fuel diversion. I agree on Lac Du Bonnet or Red Lake but those would take some fuel awareness which I think was lacking at that point of the trip.
He did fly right by Selkirk on one engine, about 5 minutes after the other one quit from fuel exhaustion. :shock: 3000 feet of gravel at Selkirk would have been best of a lot of bad choices here. So ####ing lucky flying under a powerline and getting it down on a road. Horseshoes up the backside!
SpyPilot
Re: Eagle Air
Post by SpyPilot »
The three most useless things in aviation:
The runway behind you.
The air above you.
The geothermal heated fuel that you left behind in the underground storage tank.
atc_is_god
Re: Eagle Air
Post by atc_is_god »
Stop making stupid fuel decisions that will kill your passengers and may land you in jail.
https://winnipeg.ctvnews.ca/pilot-avoid ... e-1.283887
pdw
Re: Eagle Air
Post by pdw »
J31 wrote: Sun Nov 05, 2023 8:07 pmdid fly right by Selkirk on one engine, about 5 minutes after the other one quit from fuel exhaustion
Taking another look .. that may not have ended up too much better at that unfortunate point seeing the second engine approximately lost abeam to NW about 6miles out over the extended centreline of the nw/se Selkirk rwy when already pointing south into ‘SSW 10mph’ along the country road. How would it have been different if the forced approach got messed up trying to spot land it on that threshold of 3000ft, or not getting that far.
cdnavater
Re: Eagle Air
Post by cdnavater »
pdw wrote: Mon Nov 06, 2023 2:51 pm
There’s two paved roads that run north south on either end of the Selkirk strip and several farm fields in the vicinity, plus even more mile roads in the same area, just look at google maps, it’s plentiful with forced landing areas.
Even further, this pilot would have flown right past Selkirk on a direct track from Sachigo to YAV, he made a choice to try and cover up this mistake or the gauges were over reading, my money is on him hoping to make it to base and make up some bs to the passengers about why the engine quit, never ever filing a report.
But, I’m a pessimist!
