R985 cowling shake!
West Coast Swell
R985 cowling shake!
Post by West Coast Swell »
Here's a question for you. If you have an engine with a rough shake and the cowling is rotating left to right ( 9 to 3 oclock) a bit but still running smooth rather than up and down (12 to 6 oclock) what possible problem do you have and why?
Rudder Bug
Re: R985 cowling shake!
Post by Rudder Bug »
The last time my cowling vibrated abnormally, a cylinder had sepated from the crankcase and a forced landing followed. That took place a few minutes after takeoff. The engine was running smooth despite its major dammage. I would take it seriously...
Reading this can not hurt as well:
http://www.tc.gc.ca/civilaviation/certi ... 007-02.htm
lazyboy
Post by lazyboy »
Get the prop balenced
xsbank
Post by xsbank »
Plug.
Matthew
Post by Matthew »
West Coast Swell wrote:Here's a question for you. If you have an engine with a rough shake and the cowling is rotating left to right ( 9 to 3 oclock) a bit but still running smooth rather than up and down (12 to 6 oclock) what possible problem do you have and why?
Seen this before on a Beaver.
It's like all of a sudden at a certain RPM right? I had one that did it at between 950 and 1000 rpm.
Tried everything to stop it, engine was smooth and prop was balanced.
The shake went away with a new engine and fresh engine mounts.
My advice, just keep it out of the RPM range where it shakes at all costs. It WILL start cracking cowling parts if left there a shakin' and scares the hell out of passengers.
Matt.
twotter
Post by twotter »
Check the engine mounts.. Might be time for some new ones...
xsbank
Post by xsbank »
Here's a different one for you - do all you radial drivers know what it means if your oil pressure drops from its normal level to a reading a few pounds lower and stabilises there? What is going on?
Ballsssssss
Post by Ballsssssss »
It's bypassing your screen that is full of chunks of engine so big you can read part numbers.
TT: don't care PIC: still don't care MPIC: really really don't care TURBINE: get a life.
Life's never fair, get a helmet.
buster79
Post by buster79 »
is that why it shakes? i don't think so.
Ballsssssss
buster79 wrote:is that why it shakes? i don't think so.
Reading the post above mine and maybe it will all make sense to you.... PAY ATTENTION CLASS!
Matthew
Post by Matthew »
xsbank wrote:Here's a different one for you - do all you radial drivers know what it means if your oil pressure drops from its normal level to a reading a few pounds lower and stabilises there? What is going on?
A lot of times it's just indication. But it's a good reason to stay near lakes if it isn't.
A lot of radials have seals and gaskets on oil galleries inside the engine that can begin to leak internally and cause a pressure drop. You'll never know because it won't leak on the outside.
Make sure there isn't a bird or something stuck in the oil cooler too.
Matt.
West Coast Swell
We replaced the engine at 850 hours T.T. ..... it doesn't shake any more!! Better safe than sorry.
Rudder Bug
I'm glad the problem was solved even though in a pretty expensive way. Do you have any hint of what the problem was by now?
Dr. Mcillicuddy
Post by Dr. Mcillicuddy »
Quite comen on the dhc2, Use the engine mount numbers from the otter andb your problem is solved. been doing this for thirty years and no more shakes. Try it. Dr.
Matthew
Post by Matthew »
Dr. Mcillicuddy wrote:Quite comen on the dhc2, Use the engine mount numbers from the otter andb your problem is solved. been doing this for thirty years and no more shakes. Try it. Dr.
Crap. I'm loosing my mind........ We also changed to Otter mounts in the DHC-2 when we changed the engine. I forgot about that :roll: That seems to solve it too.
Maybe it was you Dr. who suggested it 8)
