Air to Air Frequency
Fishizl
Post by Fishizl »
This is for general conversation between 1 or more ac that are enroute together and don't want to tie up unicoms etc. Is there one for Canada? I'm reading the U.S has one but don't see anything about a reserved Canadian frequency. I see one mention of someone using 123.45. Anyone?
Conflicting Traffic
Re: Air to Air Frequency
Post by Conflicting Traffic »
TC AIM COM 1.5 references AIP Canada GEN 3.4. If you go there, you get the following:
AIP Canada GEN 3.4 wrote:For air-to-air communications between pilots within Canadian Southern Domestic Airspace (SDA), the correct frequency to use is 122.75 MHz; in the Northern Domestic Airspace (NDA) and the NAT, the frequency allocated by ICAO is 123.45 MHz.
Conflicting Traffic please advise.
Flight94
Post by Flight94 »
Conflicting Traffic wrote: Wed Jan 11, 2023 2:07 pm TC AIM COM 1.5 references AIP Canada GEN 3.4. If you go there, you get the following:
Interesting, I didn't know that. I always used " the fingers". Thanks for sharing.
rigpiggy
Post by rigpiggy »
Fingers, five across, bullshit. 19.95 whiskey, 29.95 cheap suit etc....
rigpiggy wrote: Sun Jan 15, 2023 9:55 pm Fingers, five across, bullshit. 19.95 whiskey, 29.95 cheap suit etc....
I've used cheap suit, and I think there was cheap shoes too but I can't remember it.
Nighthawk1
Post by Nighthawk1 »
If you're on 126.7 some guys say "go up a nickel". That would mean to talk on 126.75 MHz.
DHC-1 Jockey
Post by DHC-1 Jockey »
Up in northern Ontario, we used to use "Go Canada" as code for 118.67 (1867 year of Confederacy).
schnitzel2k3
Post by schnitzel2k3 »
Go guns, 130.8 I think?
NotDirty!
Post by NotDirty! »
“Go Guns” would be 30-30
