I definitely read that wrong and confused it with a message above talking about purchasing TS or the jets. You simply said the routes. I knew the 195 was a bit limited I was thinking of bigger planes coming down the road. My mistake.cjp wrote: ↑Wed Oct 09, 2024 8:48 pm The jet doesn't have the range, and it's barely ETOPS. We'd need something bigger - and if that's in the works, we certainly don't know about it. E190 might be an option...but I don't see them hitting a tarmac until 2027+
We currently operate it (195) on some of it's longest routes, and those trips, comparatively, would barely cross the Atlantic Eastbound out of Toronto. Perhaps Montreal or Halifax, but then the business of flying westbound doesn't work terribly well with any sort of realistic wind.
The E2 is great for trans-continental. That's where it lives.
As I say this, it'd be funny if the powers that be send out an e-mail saying we're starting service to Heathrow, Dublin or Glasgow. Considering we haven't tried our hand at Carribean yet, and - I'm guessing - only 20% or less of current batch of pilots have gone NAT/WATRS, we'll have another learning curve coming up shortly.
E2
Re: E2
Re: E2
It's not rocket science. A ground school session and 1 sector and you'll have it figured out.
- RoAF-Mig21
Re: E2
Having over 1000 hrs on the E1, I can tell you I like the plane. I bet the E2 is even better. The question I have. Who the hell decided to design that yoke? It's the most idiotic thing I've had the "pleasure" to fly.
1. It's shape stupid (I get why. It's supposed to match your hands when they're "at rest" with a 45 degree angle to the horizon), but nobody holds it with two hands, especially on landing... and crosswinds.
2. Why is so stiff? There's a lot of force in that yoke and I don't understand why?
3. Why didn't they make the E2 with a sidestick? Does a "sidestick" vs "yoke" really change the "commonality" with previous models? Can't that be just taught as a "differences course"? (Both for pilots and AMEs)
Re: E2
1) yeah I agree, you get used to it but it’s dumb.RoAF-Mig21 wrote: ↑Thu Oct 10, 2024 5:39 am Having over 1000 hrs on the E1, I can tell you I like the plane. I bet the E2 is even better. The question I have. Who the hell decided to design that yoke? It's the most idiotic thing I've had the "pleasure" to fly.
2) never flew the E1 but I wouldn’t say the yoke is stiff in the E2. Maybe that’s the difference in having fly by wire in the E2’s?
3) I imagine it’s mostly because of the costs incurred associated with not having commonality. Countless aircraft models had design decisions made with this in mind. But I agree that a side stick would’ve been way nicer.
Re: E2
E1 has FBW except for mechanical ailerons.8895 wrote: ↑Thu Oct 10, 2024 9:52 am1) yeah I agree, you get used to it but it’s dumb.RoAF-Mig21 wrote: ↑Thu Oct 10, 2024 5:39 am Having over 1000 hrs on the E1, I can tell you I like the plane. I bet the E2 is even better. The question I have. Who the hell decided to design that yoke? It's the most idiotic thing I've had the "pleasure" to fly.
Re: E2
Interesting.
The Embraer 120 (Turbo-prop) has the same controls, built in the 80's and before the ERJ and E-jets.
https://en.wikipedia.org/wiki/Embraer_EMB_120_Brasilia
Re: E2
For sure. Just saying most of the experience is continental or Pacific, so it would be a quick pivot. a ground school for 500+ pilots starts to become a half a million dollar plus affair to get them equipped to fly NATs.
This aircraft should have come with a sidestick, not a bull horn. Common type rating strikes again.
Re: E2
Also add in the fact that the 1:50 FA rule does not apply for European means we would have to install another JS.khedrei wrote: ↑Wed Oct 09, 2024 10:35 pmI definitely read that wrong and confused it with a message above talking about purchasing TS or the jets. You simply said the routes. I knew the 195 was a bit limited I was thinking of bigger planes coming down the road. My mistake.cjp wrote: ↑Wed Oct 09, 2024 8:48 pm The jet doesn't have the range, and it's barely ETOPS. We'd need something bigger - and if that's in the works, we certainly don't know about it. E190 might be an option...but I don't see them hitting a tarmac until 2027+
It took Porter 17 years to get to were it is today, and still awaiting a minimum of 35 more tails. We need to stabilize this operation before we talk about going bigger.
I’d say if it occurred it would be via wetlease, which would be limited by the CBA.
Re: E2
Well since Concorde is mentioned, perhaps I can suggest you a "clue" regarding the origin of the design of the yoke :
https://youtu.be/KqJaRa4jdHo?si=p9deitOIV5ggWRcM
starting from 0:50
(personal translation) "... so it's the last flightdeck that was arranged in the most modern way for the time - but that is still old though; with particularities : for instance, the wheel here has a special shape, which is my own drawing - to clear view of the instruments of the dashboard. It was quite criticized at first but in the end everyone was satisfied with it."
(Regarding the last sentence I guess Romanian MiG-21 will beg to differ)
André Turcat, Concorde chief test pilot
Re: E2
I think the Bristol Britannia had the M shape before.AirInter wrote: ↑Fri Oct 11, 2024 9:01 amRoAF-Mig21 wrote: ↑Thu Oct 10, 2024 5:39 am Having over 1000 hrs on the E1, I can tell you I like the plane. I bet the E2 is even better. The question I have. Who the hell decided to design that yoke? It's the most idiotic thing I've had the "pleasure" to fly.Well since Concorde is mentioned, perhaps I can suggest you a "clue" regarding the origin of the design of the yoke :
starting from 0:50
The drawing/Shape Andre Turcat referred to is the weird U shape connecting the handles.
That being said, EMB introduced it in the 120 I think, inspiration from the concorde could be it.
Re: E2
It doesn't make sense at all to send the E2 across the pond. It simply can't compare to the 321N or 737Max, on those segments financally. Nor was it designed to conduct such an operation. It's powerhouse is short segments with high ultilization, with the flexibility to do some longer transcon.
Re: E2
The suggestion that an E2 fly ‘overseas’ is a joke. Except perhaps some of the shorter WATRS routes to the Caribbean.330heavy wrote: ↑Fri Oct 11, 2024 12:10 pm It doesn't make sense at all to send the E2 across the pond. It simply can't compare to the 321N or 737Max, on those segments financally. Nor was it designed to conduct such an operation. It's powerhouse is short segments with high ultilization, with the flexibility to do some longer transcon.
Re: E2
Any updates on the benchmarking? Also have any of the growing pains subsided now that deliveries have slowed down? And on that topic, is it a temporary slow down in deliveries or will PD not take the rest of the options? Seemed like there were like two or more tails a month being delivered at one point.
Re: E2
Yes some of us anticipate some more of our routes to Porter, such as CUN, PUJ, POP etc., like FLL, MCO, etc from YYZ that was given to them. Hope that's not the case, but rather an enhancement of frequency to our operation. As always, time will tell. Overall, the JV is great and beneficial to both operations.rudder wrote: ↑Fri Oct 11, 2024 12:12 pmThe suggestion that an E2 fly ‘overseas’ is a joke. Except perhaps some of the shorter WATRS routes to the Caribbean.330heavy wrote: ↑Fri Oct 11, 2024 12:10 pm It doesn't make sense at all to send the E2 across the pond. It simply can't compare to the 321N or 737Max, on those segments financally. Nor was it designed to conduct such an operation. It's powerhouse is short segments with high ultilization, with the flexibility to do some longer transcon.
Re: E2
Agreed. Not happening. Carib routes maybe. With planning from the JV with Transat. No one is trying to steal routes.rudder wrote: ↑Fri Oct 11, 2024 12:12 pmThe suggestion that an E2 fly ‘overseas’ is a joke. Except perhaps some of the shorter WATRS routes to the Caribbean.330heavy wrote: ↑Fri Oct 11, 2024 12:10 pm It doesn't make sense at all to send the E2 across the pond. It simply can't compare to the 321N or 737Max, on those segments financally. Nor was it designed to conduct such an operation. It's powerhouse is short segments with high ultilization, with the flexibility to do some longer transcon.
The E2 is a continental machine. Finding a spot for life rafts would even be tough. I’m sure they have spots for them, but it’s not what these things designed to do
Re: E2
Yeah I think all this over thinking came about with the horrible thought of losing Transat with the current state of affairs.330heavy wrote: ↑Fri Oct 11, 2024 1:52 pmYes some of us anticipate some more of our routes to Porter, such as CUN, PUJ, POP etc., like FLL, MCO, etc from YYZ that was given to them. Hope that's not the case, but rather an enhancement of frequency to our operation. As always, time will tell. Overall, the JV is great and beneficial to both operations.rudder wrote: ↑Fri Oct 11, 2024 12:12 pmThe suggestion that an E2 fly ‘overseas’ is a joke. Except perhaps some of the shorter WATRS routes to the Caribbean.330heavy wrote: ↑Fri Oct 11, 2024 12:10 pm It doesn't make sense at all to send the E2 across the pond. It simply can't compare to the 321N or 737Max, on those segments financally. Nor was it designed to conduct such an operation. It's powerhouse is short segments with high ultilization, with the flexibility to do some longer transcon.
They're an amazing partner. Nothing but respect for you guys. Love traveling with you, and likewise, the odd time when you guys are onboard, returning the favour.
Re: E2
Personally I do not think we will be hitting the Caribbean from YYZ unless it is the less desirable locations. When you can fill a 330 to CUN, why operate an E2. What I could see is YYZ-Tulum, YQT/YXE - CUN etc. But not from the main established hubs.330heavy wrote: ↑Fri Oct 11, 2024 1:52 pm Yes some of us anticipate some more of our routes to Porter, such as CUN, PUJ, POP etc., like FLL, MCO, etc from YYZ that was given to them. Hope that's not the case, but rather an enhancement of frequency to our operation. As always, time will tell. Overall, the JV is great and beneficial to both operations.
Re: E2
You just do it in higher frequency. Costs for an E2 are about 1/3rd of the 330, perhaps slightly less. If we've got more birds and pilots to throw at the problem, problem solved as long as we can secure airport slots.flyinhigh wrote: ↑Sat Oct 12, 2024 9:50 amPersonally I do not think we will be hitting the Caribbean from YYZ unless it is the less desirable locations. When you can fill a 330 to CUN, why operate an E2. What I could see is YYZ-Tulum, YQT/YXE - CUN etc. But not from the main established hubs.330heavy wrote: ↑Fri Oct 11, 2024 1:52 pm Yes some of us anticipate some more of our routes to Porter, such as CUN, PUJ, POP etc., like FLL, MCO, etc from YYZ that was given to them. Hope that's not the case, but rather an enhancement of frequency to our operation. As always, time will tell. Overall, the JV is great and beneficial to both operations.
Re: E2
A330 can seat as much as 3 E2's can. You are now paying for 2 extra slots, 2 extra crew, maintenance, etc to move the same amount of pax.cjp wrote: ↑Sat Oct 12, 2024 2:29 pmYou just do it in higher frequency. Costs for an E2 are about 1/3rd of the 330, perhaps slightly less. If we've got more birds and pilots to throw at the problem, problem solved as long as we can secure airport slots.flyinhigh wrote: ↑Sat Oct 12, 2024 9:50 amPersonally I do not think we will be hitting the Caribbean from YYZ unless it is the less desirable locations. When you can fill a 330 to CUN, why operate an E2. What I could see is YYZ-Tulum, YQT/YXE - CUN etc. But not from the main established hubs.330heavy wrote: ↑Fri Oct 11, 2024 1:52 pm Yes some of us anticipate some more of our routes to Porter, such as CUN, PUJ, POP etc., like FLL, MCO, etc from YYZ that was given to them. Hope that's not the case, but rather an enhancement of frequency to our operation. As always, time will tell. Overall, the JV is great and beneficial to both operations.
Re: E2
It would be just the extra slots technically if a 330 costs (wet) 3 times the E2 to operate. Again I don't have much more than Google searchable numbers (that's the level of effort I put in). I don't know what slots go for in Pearson or Cancun so tough to really measure.Me262 wrote: ↑Sat Oct 12, 2024 8:52 pmA330 can seat as much as 3 E2's can. You are now paying for 2 extra slots, 2 extra crew, maintenance, etc to move the same amount of pax.
