Ontario float bases
Ontario float bases
I need to ferry a floatplane from Kitchener to Thunder Bay. Other than Bar River, does anyone have any info where else that I could stop and pick up Avgas?
Re: Ontario float bases
Azilda (White Water) operated By Sudbury Aviation outside of Sudbury
There is a float plane base around Orillia, on lake St-John (I think). It is close to the casino and there is also an airport.
- lionheart27
100LL PN Humphrey Aviation Service 705-542-2590 CPX8
CNV7 Patridge Point Fuel & oil avbl May-Oct 13-17Z‡ Mon-Fri, O/T PN
CPJ9
Manitowaning Seaplane Base only mogas
Algoma Mills private Lauzon Aviation Co Ltd. 705-849-2389 Reg PPR?
Carry Jerry cans and claim limited access!!!
CPJ9
"Traveling through hyperspace ain't like dusting crops boy"
"Up the Irons"
"Up the Irons"
Wawa has a couple of float bases. Geraldton has fuel. You land on Hutchison Lk beside the airport and they will bring the bowser and top you up.
I’ve done that trip twice but from Gatineau. I stoped at azilda(Sudbury aviation). Then up to hawk junction just east of Wawa. Hawk air. Then to Gerlton.
Can someone get me some more info on fuel in wawa. Watson's only has jet and Air Dale phone number doesn't work.
Hawk junction phone doesn't work either.
https://www.hawkair.com
This is the website for the operation on Hawk Lake. I believe they still operate a piston beaver and C180 so should have avgas. Not sure on sales though.
I am pretty sure Forde Lake Air out of hornepayne will sell gas with prior notice. At least they did the past few years. Not sure if this will help for flight planning.
Air Dale is no longer operating, so that base in Wawa is not active. Similarly, NV7 (Partridge Point) is closed as well. Hawk Air in Wawa is your only option there.
If you're passing through the Sault area, the Bushplane should work, or PM me and I'll help you out.
Hawk air is who you want to call. They are on hawk lake.
